6volt headlight bulbs for 36hp style lights
https://forums.aussieveedubbers.com/threads/68889/6volt-headlight-bulbs-for-36hp-style-lights
nicko ·
I am after 2 6 volt headlight bulbs for early style headlights (36hp beetles and buses) I dont mind if they are new or second hand- as long as they work. Does anyone have any or suggest where I can get them. Have tried voksbahn and George at VW Classic with no luck
Nicko
Sulla ·
Can you please post an image oif the bases as I may be able to help.
Pumba ·
I have some from a 67 beetle are they the same???
bond ·
far out. i threw out about 10 last week.
nick
nicko ·
They look like this http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=N177011 67 ones are different. Is this pic enough Sulla to see what I need?
Nicko
11CAB ·
I may have a pair, will have to check tomorrow
Ian Bugden ·
Try repco/autopro as they can order in most stuff like that.
there is a guy in Adelaide
who sells Quartz halogen 6 volt headlamp bulbs to fit early VWs...
He sells bulbs all over the world..
I don't have His info any more..
but if You want just standard early VW bulbs
[pearshaped]
many people will have them laying around...
best of luck
Sulla ·
Hi Nicko.
Your link matches the bulbs I have. Two pins on the sides. The narrow pin being about 3 mm and the wider being about 4.5 mm; with two oval shaped contact points. Base about 20 mm in diameter. Type is BA20D. $20 for the pair (brand new, tested and working) including postage. PM if interested.
Sulla
nicko ·
Thanks Sulla but I have found some already. If it doesnt work out I will get them off you.
Nicko
Sulla ·
No problemo!
