exhaust leak
https://forums.aussieveedubbers.com/threads/68912/exhaust-leak
donn ·
This should be easy, exhaust is not sealed properly against the motor causing it to backfire when backing off, is there some compound or different gasket I can put there to seal it off.?
Don
hellbugged ·
just get a new gasket, shouldn't be a need for sealant
You may find the flange is not true to the head also?
donn ·
Mat you have got it spot on but whats the best or easyest way to overcome the problem?
easy to fix...
Use black RTV silicon [Dow Corning} 732
coat both sides of the gasket with it
let it harden slightly, then bolt it on
Gauanteed no leaks....
donn ·
cool, knew there would be an easy fix and knew this was the place to find out, just thought it would be a more hi tech sealant. thanks
