Aussieveedubbers 路 Tech Talk
Beetle and Bus weights? how much pls
https://forums.aussieveedubbers.com/threads/68995/beetle-and-bus-weights-how-much-pls
h 路
hey all..
i have my 54 type one and would like to know its approx weight - standard weight is fine
+ would also like to know how much a 76 model microbus 8 seater bay would weigh as well??
thinkin of getting a car trailer and want to know what i should build it for with weight in mind?
come to think of it if anyone has a tandem car trailer that takes these breeds can you put some measurements up here so i can get some ideas turning over in my skull pls..
thanks
pauly
guru 路
Try this site http://www.carfolio.com/
It will tell you EVERYTHING.馃お
h 路
i tried it but my puter doesnt like it for sum reason..
anyways anyone else got some ides..
cheers paul
greasykitchen 路
Don't know about a '54, but according the manual for the beetle I used to own, a '71 ish model is 820kg.
Joel 路
early beetles from memory are about 740-760
Lbugs are the heaviest of all beetles at 860KG
guru 路
'53 beetle 892 kg 1131cc 24.5 bhp @3300rpm 49ft.lb @ 2000rpm
'55 beetle 737 kg 1131cc 30bhp @ 3400rpm 56 ft.lb @ 2000 rpm
no '54 listed. no type 2 stuff.
h 路
cheers for that..
anyone have any T2 info pls
taa pauly
modulus 路
Microbus std (221) 1380 unladen, w'out driver
Microbus deluxe (241) 1425 unladen, w'out driver
hth
h 路
modulus approx what years are those busses you quoted pls..
taa paul
h 路
OberonViking 路
Those bus weights would be very close for 69 - 79. My 1979 Microbus is 1300 kg TARE.
modulus 路
'72-'79 with the TIV engine. I don't have any data for the 1600 variant of the Bay.
hth
LIFE IN THE LOW LANE 路
take about 15-20 odd kg off for 1600.
