Gene Berg shifter
https://forums.aussieveedubbers.com/threads/69010/gene-berg-shifter
Mick058 ·
Took the handle off with it in the car and now i can't get the reverse cable that goes through the middle to slot back in...whats the trick???? or do you need to unbolt from the chassis???
unbolt it to assy
Mick058 ·
Whats the way to align the gear shift once removed? stick it in second gear then re-tighten the bolts?
Whats at the bum end of the berg shifter? How is the cable hooked up to the reverse shift?
i think theres a cabel with a crip on the end of it
yes adjust while in 2nd gear and centralise it b4 tightening
