Cable
https://forums.aussieveedubbers.com/threads/69031/cable
donn ·
need to know the diameter of the fitting on the g/box end of the clutch cable, anybody out there can advise?
thanks
don
Do You mean the diameter of the hole IN the clutch arm ??
donn ·
No, the diameter of the fitting on the end of the cable, I need to know so that I can make up a cable (needs to be shorter than standard for a short wheel base pan) that I can push through the tube in the tunnel
Old Dubber ·
6mm
donn ·
Ta
Brian ·
7mm thread 👍
donn ·
????????????? 6mm with a 7mm thread? got me there but at least I have a starting point, thanks for the help.
The thread is M7
