gearbox gurus... advice required!
https://forums.aussieveedubbers.com/threads/69114/gearbox-gurus-advice-required
I had a 'spare' single-side IRS gearbox that had about 3-5mm side-to-side play in the output flanges (ie: the diff) so tonight I stripped off the drive flanges, side cover and pulled out the diff. The bearings beside the diff (carrier bearings) are pitted/scored and flogged out - one side in particular - but when turned by hand, the remainder of the box feels nice and smooth and teh drive pinion and ring gear look okay. So I'd like to get it back together and use it in a car
Is replacing these bearings a simple matter of 'off with the old and on with the new' (with help from a mechmaniac/gearbox shop)?
How is the side-play/mesh of the R&P set-up? When I pulled out the diff, there was what appeared to be two 'crush' washers on the *outside* of the bearings, where logic tells me they should be on the inside...? Maybe someone has incorrectly assembled...?
Advice/hints appreciated! The only books I have deal with swingers
I'll try get some pics to help explain...
dangerous ·
The backlash is set by shims that are under the bearing cups.
The total amount of shims controls the bearing preload as well.
So the whole stack remains the same once preload is done,
while setting backlash.
There is a shim under the pinion bearing also,
but you will not go that far.
Try to get the same part number AND brand of bearing and you have a good chance to make it a "bolt in swap".
There should be no play in the CV flange once the circlip is on,
and the spacer goes on first, then the CV flange.
Try just the new bearings, and feel for backash if you do not have a dial indicator.
The corect number is 0.15 to 0.25mm.
Do this as a trial assembly before the seals go in.
The bearing cups will need replacing,
and a piece of 60mm tube turned down about 59.9mm will remove the cup without damaging the shims.
Dont mix up or lose the shims.
LIFE IN THE LOW LANE ·
who needs a manual with Dangerous around......
well said Dave
should he " blue " the ring n pinion to see if theres the correct contact on the gears
or not worry too much about it
Hey thanks for the clarification lads, Dave I did not know there were shims behind the bearing outers/cups. There was about 5mm side-play (in the whole diff - through the gearbox case) and a big 'clunk' between the pinion and crownwheel so I will replace the pitted/damaged bearings (I wonder how that happened) and see how things line up...
dangerous ·
You can double check the pattern with 'blue' if you want,
ust in case the pinion has moved.
Some times the LHS bearing pounds into the 'hat' that forms part of the carrier.
You will see what I mean if you find the bearing cone loose on that side.
Other than that,
just loose berings can create a lot of movement when they lose that hard layer and have alkl that pittig.
Pay close attention to the teeth on the crownwheel and pinion,
and remove any burrs if it has been run like that.
yeah Dave it is the 'sideplate' side bearing that is (most) stuffed; the pinion and crownwheel look okay (no obvious damage or burrs etc) so I'll do the bearings, use the same shims in the same place, and cross my fingers 🙂
