WTD: Heater tubes for Oval
https://forums.aussieveedubbers.com/threads/69123/wtd-heater-tubes-for-oval
Nevada51 ·
Looking for a set of oringal heater tubes that run between the engine heater boxes and the body for a '56 oval. Any 36hp ones should do the trick. 50mm internal diameter at both ends apparently.
Like these:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111255355
What have you got - I'm located in melb.
Cam
Yes,
they were made of a sort of convoluted steel
Thousands have probaby gone to the tip...
You can Use heater hose...50mm VW Heater hose
I use the silver heater hose [painted of course]
I suggest that u purchase the ones from Wolfsburg West they will be best quality and there dirt cheap at $35 USD
whatnow ·
i'm sure i have some in my stuff in sydney. i'll be down that way for the nationals if that helps.
Nevada51 ·
Thanks for the replies. Lee - I'm keen to keep it looking very original so I'll look at your suggestion if I can't get a set elsewhere 👍
The WW ones are cheap but once you add in postage they become horrendously expensive. I should have ordered some in any of the last three orders I've done with WW but I just didn't think they'd be that hard to find 🙁
Henry - have sent a PM
You usually see them at swap meets
as many people don't use heaters..
but VW owners in Melbourne probably do... lol..
