intermittent starting problem
https://forums.aussieveedubbers.com/threads/69189/intermittent-starting-problem
mike95 ·
I have a 1970 type 3 squareback, & am having an intermittent starting problem.
Around 1 out of every 4 to 5 times i turn the key to start the car, i get a single click
& the car doesn't crank over. Nothing happens.
i turn the key back to the off position & try again & usually within 3 or 4 attempts
the car cranks over & starts as per normal.
Some days, it starts first turn of the key, & others it takes a few attempts to get it to crank over.
Any ideas as to why this is happening. Is it the sign of a failing solenoid or starter motor?
Car has a new battery (only about 10 days old), & because it eventually cranks over, im fairly sure its not the battery.
Mike
Try fitting a starter relay 1st.
mike95 ·
Thanks,
i will give that a try.
check all the battery terminal connections and the main cable to the starter
and clean lubricate slightly (vaso ) and tighten the earths especially
