Yeha crew.
Wondering if anyone of us here has stripped down a Dizzi on a T3 2.1ltr?
If so How does one remove the pin in bottom of shaft?
Or is there another way to get at the top side of dizzi ( where wires connect) ?
I cant see how it's possible.
Started out fixing the water pump, mount cracked on bottom of AC compressor then caught the wiring on side of dizzi releasing one wire(earth) from connection..
So a day job has turned in to a nighmare..
Apart from this option does anyone have 2nd hand dizzi?? Model 415
How much?? pm/u2u me.
Oh all this started because vehicle was at standstill after not wanting to turn over. Got opwer at both ends Ignition and Starter, got power when turning key at starter pole 12.75Volts..
I aint push starting the bloody thing all the time.
Should one suspect a bad soleniod???
My love of Kombi's is always tested
Iwish4aSynchro ·
