narrowed sway bars
https://forums.aussieveedubbers.com/threads/69372/narrowed-sway-bars
cnfabo ·
where can u buy narrowed swaybars??
and has any one been questioned on why they arent running one on there narrow beems when going over the pits??
Brad ·
they are not narrowed they are custom. A sway bar can;t be modified as such. Sway - A - Way and Whiteline both make custom ones and you just need to order one, there are people on here that have done it.
The other option you have is just make your own out of mild steel. It will do bugger all but if you are worried about a pits inspection they will not pick it. Usually speaking most guys wont pick you for not having one at all.
'Wont get pinged for not having one at all' is because pre '58 never had one std.
as per above there not required, and can be removed for registration
Where are you located as you will need to have yr front end measured by some one who knows wht there doing to havea new sway bar made to order
cnfabo ·
sweet ill just go c a whiteline dealership or whoever!!!!!
Brad ·
matberry wrote:'Wont get pinged for not having one at all' is because pre '58 never had one std.
mm ok but how did you know he was talking about pre 58 ?
