Regualtor wiring issues
https://forums.aussieveedubbers.com/threads/69373/regualtor-wiring-issues
Mick058 ·
I have (i believe) a 55amp bosch alternator and a RE57 bosch regulator and am having charging issues.
If i have the wiring one way, it seems to last a little bit then suddenly drop from 12volts down to 8 volts in about 25min or so, and then my spark is no good so the engine just stalls.
If i have it wired another way it over charges. My dash gauge says 18volts when im driving alone and 14volts when idling.
When i check the battery terminal on the alternator at idle it reads 16-16.5volts.
Any ideas guys? Very frustrating issue.
The terminals i have to play with are:
Alernator: D+, D-, DF
REgulator: D+, D-, DF
greedy53 ·
i think your regulator is playing up as it gets a bit worm it starts to faulter not uncoman what ti do is borrow new on and go from there
dont do the switch a bout to 18 volts it can and most likely goes up to 30 volts i know blew thw liven shit out of the coil and fryed the condensor and points
good luck
Take it to the Auto Elect near Boris
sounds like my problem i had
Mick058 ·
Where abouts is he Dave? Fault is a pain in the butt.
at the top of Chelmsford Ave the street B4 Vintage of Harp
on the corner of forbes lane just b4 canterbury Rd
Mick058 ·
Mick058 ·
Are the called auto tech electrics
