well girjs and boys i'm having a bit of bother with the gear shift into 1st gear cold it's easy warm it starts to get a bit harder until you really have to give it a savage push 馃お
is it a ajustment or a clutch job
1303Steve 路
The firewall on that model often fractured where the cable goes through, and old lawn mower blade is a good shape for a repair.
greedy53 路
thanks steve that has been done a bit more info it dose not matter how much i tighten up the clutch adjustement it stays the same
i was wondering if the shift was in the correct alignment is there a ajustment part on these
1303Steve 路
The plastic bushes wear out a bit on those. Maybe you should talk to Matt @ Camden GTI, he knows all about this stuff.
greedy53 路
now there is good idea thanks again
99gti 路
Yup - MAtt from Camden GTI would be my recomendation also.
