I fitted a 009 that had not been used for many years, its in good condition and was bought in the late 70s so its a good German one.
I fitted a Pertronix Ignitor II along with the correct flame thrower coil and I had a slight miss at light throttle, I blamed this on the leads which I replaced and the miss gradually got worse.
Today I removed Pertronix unit and fitted the stock points and condenser, missfire is now gone.
I had to really push hard to fit magnetic collar, can these be damaged? Its not split or anything like that.
When I read the instructions it mentioned a correct air gap, the Pertonix unit I bought is the 009 specific and is non adjustable.
I also noticed that I was getting some pinking/pinging, I'm not getting any pinking/pinging with the points fitted on the same timing.
According to Pertonix II "Adjusts spark timing over the entire RPM range to compensate for the inherent electronic delay resulting in more stable timing." Maybe this caused the pinking/pinging?
Any ideas?
1303Steve 路
