Aussieveedubbers · VW Circuit Racing
Braided Brake Lines in Brissy
https://forums.aussieveedubbers.com/threads/69721/braided-brake-lines-in-brissy
BiX ·
Does anybody have a lead on who suuplies braided brake lines in brissy? Or who can make them? prefer adr approved.
Drew
http://www.braidedhoses.com.au/
LIFE IN THE LOW LANE ·
The Brock Shop at Springwood. Did all the braided lines on my brother's Type 3 and all ADR approved with the tag and codes attached to each line.
Brad ·
BHSS are the cheapest in Brissy that I can find
Sides ·
I haven't had braided lines made up by them (yet) but I've found Slacks Creek Brake & Clutch pretty good for a few things... like hard lines and other "weird" bits to make a 944 master cylinder fit into a bug nicely. I'd asked about the braided lines, and was told to expect about $90 per corner, varying a bit with length.
BiX ·
Due to time constraints over the last week and this week, i have jsut grabed some normaly flexiable lines. But once the move is done, I will be getting soem made up, so might ring a few of those ppl and sort it out.
Drew
Brad ·
$90 WOW that is a rip off. BHSS where under $50
Buggy Brad wrote:$90 WOW that is a rip off. BHSS where under $50
And their service is usually fantastic.
dangerous ·
Who is BHSS?
Location and phone number?
MikeM ·
http://www.bhss.com.au/
They are even cheaper in bulk. Expect to pay under $40 a hose if you get a few friends together and put in an order for multiple cars at the same time.
The easiest way I've found is to take them a sample (ie current factory hose) and they will dublicate it in braided.
the ones we got made from the brock Shop cost about $400 from memory. But the rear lines we got made in braid run from the calipers all the way up the trailing arms to the block at the end of the tunnel. So they are almost 800mm odd long which wasn't cheap but I will certainly look at BHSS if they are as cheap as you guys say. Are their lines fitted with the DOT approved tag??
MikeM ·
Are BHSS lines fitted with the DOT approved tag??
Yes. I will post a pic when I am in the workshop this weekend.
Tell them the Manx Dune Buggy Club sent you!
