Aussieveedubbers 路 Tech Talk
Slipping clutch (Squareback with 1835cc)
https://forums.aussieveedubbers.com/threads/69795/slipping-clutch-squareback-with-1835cc
satori 路
Hey everyone. Have just put my 1835 into my squareback. After driving it for 1 hour the clutch started sliping when changing gears. Was just told that I need a performance clutch for it and will cost around $450 - 500. Will this cost any major damage if I drive it around for a few weeks. I noticed when I change gears without any accelaration it doesnt slip much. Any thoughts about this would be great as I am driving down to adelaide tommorrow.
thanks guys. 馃檯
johny rotten 路
a std clutch will hold an 1835 easy
you don't need a performance version.
are you loosing any oil ?
1303Steve 路
Do you have the correct free play on the pedal?
1500S 路
Has the friction face of the flywheel been skimmed without taking equal amount off the mounting face?
DH
satori 路
Took engine back out today. I think that I hadnt tighten the 6 bolts up to the correct torque, as after I did this the clutch seems to be ok. Fingers crossed.
satori 路
Now I know whats goiong on. After tightening the pressure plate bolt up, the clutch seemed to be working ok, but then out of no where it started grinding when I pushed the clutch in. The problem that the engine was set up for a Automatic and had the same fly wheel nut used, not the manuel one with the baring inside. Replaced it and everything is running smooth.
