Hi everyone. I am a new member !!! i dont own a vw. but i do have m mg tf. The new mg. Currently i am not happy with the power. and i was looking to put a wrx engine in to it. after searching the web. found this web site is the best tech support !!! anyway i am in sydney . at this point of time i am just wondering what i might need for this conversion and where to start. plus if you could tell me the cost of this conversion. like the engine package cost and approx labour costing ets.... thank you
The WRX is a 'flat' boxer design, the MGF uses an in-line four cylinder. In short, forget the WRX conversion as the engine won't fit
ash83 ·
if the wrx dosnt fit. then what would be the best turbo engine i can fit ???
I have seen a honda v tec fitted in mgf. link www.goldenwheels.co.uk/
But i want a turbo charged engine . what would you suggest ????
you could turbo what is there - but I hope you have $
Turbo Nissan 2.0 litre 4 cylinder RB20DET
Cost to get someone to do all the work drive in drive out may cost between $10,000 and $20,000. That is if an engineer will approve it.
Baja Wes ·
I think Helbus means the;
Turbo Nissan 2.0 litre 4 cylinder SR20DET
The RB family of engines (20,25,26 etc) are 6 cylinders and much longer than the SR 4cyl motors.
I think you should sell the MG and buy something else faster. It will be much cheaper.
Yes Wes, The SR 4 cyl, that's the one. I was RB'd on the brain.
A guy at work has fitted one to his MGB. There are no plans or pics though, he just makes it fit and work.
Is April the 1st already?
pete wood ·
ash83 wrote:if the wrx dosnt fit. then what would be the best turbo engine i can fit ???
your other alternative is an mitsubishi EVO motor. 4G63 is the code i think. Just remember, what ever you use, you'll need a gearbox that can hand the power.
Hang on a minute. Doesn't the MG is a very similar motor to the Lotus Elise? There are a number of turbo kits for them.
If you really want a WRX you could do it, however, it would take a lot of engineering. You'd need to use a subaru tranny and mount is all under the rear of the car. Doable, but why bother when you could just turbo the original motor.
ash83 ·
Yes I could turbo charge my existing motor. And lotus elise used the same motor for a while. But the motor it self is not vary reliable.
Ok if i would have to turbo charge what is the rough figure ?? cost wise. even a vary low boost 5psi??
or will it be cheaper to change the engine and gear box from jap engine to make a monster ???
anyone knows any garage around banks town who does this kind of performence works ???
pete wood ·
honestly, for a turbo/intercooler/ECU on your stock motor, I'd plan around $5k minimum. I'd check some UK sites out for kits. someone must have done it.
A swap will cost more. I'd say at least $10k by the time it's finished, engineered, aproved and the like.
Honestly, the best thing you can do is sell the MG and buy a series 1 or 2 toyota MR2. Cheaper, billion hot up parts available, everyone knows what to do to them, etc, etc.
MGs are rovers, rovers are....well you know. 👎 no offence. 🙂
THUDKNUCKLE ·
ill have to second helbus on this one if you must do a conversion Sr20det
very nice motor lot of power , light weight , tough as, and a huge support market for them
seagull ·
300 hp out of my stock sr20 🙂
MikeM ·
Just sell it and buy a WRX. They drive better anyway.
THUDKNUCKLE ·
but they dont have the character or as much fun factor ( it doesnt have to be fast to be fun )
Baja Wes ·
sell it and buy a silvia then...
rocknrob ·
look at what your MG is worth and add on the cost of modifying it then try and figure out what it will be worth as a modified vehicle. if the numbers don't scare you then go for it! modifying cars is fun...that is why we are all here👍
johny rotten ·
the first thing that comes to mind would be a Rover all alloy V8
ash83 ·
johny rotten wrote:the first thing that comes to mind would be a Rover all alloy V8
rover v8 ?? would you have specks for that ??? and which car does it come from ??
Dero ·
P76 4.5 Ltr Alloy V8....
seagull ·
I have a toyota v8 half cut $1800.00
of I have a MX5 half cut low k auto , now that would be sweet mmm
frenzix ·
Have you ever owned one? no offense but they are shit
Baja Wes ·
Forget any old V8's, and most import engines. The big problem with trying to do a conversion on a current model car is satisfying emissions requirements. You have to put in an equivalent or newer engine for the conversion to be legal. Almost anything to come in through a jap importer won't be new enough to satisfy this requirement, and even current jap cars don't necessarily meet the euro emissions level that the MG is likely complying with.
I really don't think it'd be worth trying to modify the MG, unless you decided to turbo what you already have, which has it's own set of problems.
seagull ·
I have seen two blow up 🙂
johny rotten ·
They can go very well with a little love,
no offense but I think Subis are shit, so its each to his own😂
Rota\_Motor ·
forgive me if I'm getting mixede up, but someone said its the same motor as some Elise?? which motor is it, the Rover motor, or the Toyota??
if its the rover, and the toyota can fit where the rover cdoes, maybe consider a late model toyota powerplant, MR2 or Celica, Camry or Corolla, the biggest that will legally fit. Do some research and you might be pleasantly surprised.
but it will still probably be cheaper and easier to sell the MG and buy somethng faster. Silvia/200SX, WRX, EVO lancer, MR2, Celica, there are plenty of faster options to suit pretty much any budget, if you decide to go that way, and most will be much cheaper than upgrading what you got.
Having said that, if you love the MG, and what it faster, feel free to pour all the cash you want into it.
