izac ·
¨Im keeping it!¨ izac's '65 Square... Some VW pics from Peru aswell
https://forums.aussieveedubbers.com/threads/69847/im-keeping-it-izacs-65-square-some-vw-pics-from-peru-aswell
bond ·
nick
izac ·
just up the hill at wilston ey, sweet man... what dubs do you have at the moment?
have probably seen them round...
izac
bond ·
custom veedub are down the road at stafford "hayward st" opposite the stafford tavern if you run into any issues.
pete and dave - absolute champs and know their shizzle.
nick
keegan da pirate ·
Good luck with it.
izac ·
keegan da pirate ·
izac ·
the back is at least 20mm lower than the front so I have a bit of levelling ahead of me.... 😏
also, i have suspected this for awhile but the right handside, especially at the back seems to be about 25mm lower than the left....??? when I did the rear the spring plates looked to be in the same position before and after, so i am not sure how this works ❓ i am thinking about trying a 'tuning move' on the right hand side to bring it up a bit but im not sure how this will work if plates are in the same place already ?????
when disconnecting the hand brake to get the spring plate around the cable, the cable pulled down into the tunnel... i am not sure how to get it back up and through?
thoughts would be very welcome...
still havent got the floor done yet... hopefully getting it towed to Custom VeeDub and getting it replace very sooon...
new exhaust system and shocks are also on the list
variant ·
Had the same problem with mine that the right sat lower. Adjusted the other side by one notch.
LIFE IN THE LOW LANE ·
decked dubby ·
izac ·
J BOMB ·
Dilbert ·
izac ·
still havent got the rear back up where i want it yet, tried on sturday but didnt go according to plan - please have a look at my ' type 3 rear lowering' thread in type 3s and ghias if u can help please
much appreciated
izac
Nevada51 ·
izac wrote:thought this pic looked cool 😎
Got to love a slammed square 🙂 good luck with it, its looking awesome so far.
greedy53 ·
izac ·
finally got the height to where i want it last week, so now i can get it out of the drive way 👍 and onto the tow truck....
a little less negative camber as you can see haha
fixed the fuel leak (i think) took a couple of go's - first time the hose was too big i think...
taking it into custom veedub tomorrow and getting some work on the engine and the floor done.... 🙂
heres some pics of how it is sitting now
and some rust spots etc
left hand rear fender
right front fender
pasenger floor pan
and wait for it.....
drivers side floor
notch-72 ·
Good luck with it all.
izac ·
got them for just over a grand with 135/165 nankangs and wolfsburg caps to boot! all brand new thanks Ronnie 👍
not sure about the 135s though, look terribly skinny! might swap them for something a bit wider was thinking some Federal FD1 165/50s
cant wait to get them on the car but will have to wait a bit longer (hopefully some time this week) as it is still at Custom Veedub and when Pete gets back from fraser...
the car will hopefully be on the road in the next couple of weeks... its had main seal done, trans out replace axles (might have to slap some short axles and tubes in there as the wheels (MWS repro brms) only have ET25 offset but should just tuck in with that negative camber!) ..... still gotta replace that passenger side floor..
plans after that are some new carbies for a bit more oomph, been looking at these http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D47%2D7341
but have restrictions due to the small space under the engine lid... any suggestions or advice would be good
have a stock 1500 (sp i think) with twin solex carbs that need replacing
izac ·
going to get it registered tomorrow. hopefully its not too low for them...🤪
cant wait
izac ·
got the plates without any trouble on friday! the lady didnt even come out to have a look at the car!!🤓
heres some pics with her new shiny plates and front wheels.... back wheels arent on because i will have to either put short axles and tubes in or modify the fenders to make them fit with no rubbing.
thanks to Pete, Dave and Eileen at Custom Vee Dub for helping to get it this far!
and also my dad.😉
took her for another short drive yesterday with new wheels and 135s on. no rubbing at all with the 135s but did notice a rubbing noise coming from the back left wheel - im sure its not the tires scrubbing because i have the stock wheels on the back but thinking it might be the drum.
The engine is running well and is freakin LOUD with new Thunderbird exhaust 👍 got some dirty looks from some elderly ladies while driving past them in the street 😂😂😂
heres some pics
also looking for a new latch for rear door if anyone can help out (have put post in buying selling parts forum)
Euro_67 ·
Great looking square !izac wrote:: did notice a rubbing noise coming from the back left wheel - im sure its not the tires scrubbing because i have the stock wheels on the back but thinking it might be the drum.
Check the Castle nuts on both rear dums. They work loose over time and cause the drum to wobble on the spline of the axle.
I had this problem on my last early notch. If it is left unattended for long, the spline inside the drum will wear out and the nut will continue to loosen no matter how tight you do it up. If this is the case, a good used replacement brake drum is the only option.
I hope this helps.
Wayne
izac ·
it seems to be making the noise once every rotation of the wheel... will check it out today.
pete wood ·
izac ·
izac ·
i then took the front of the drum off and the shoes look a bit worn... not sure if that would be it❓ when turning the drum by hand it is loose but when you get about half way round it is really stiff and difficult to turn... what can i do about this?
choppa ·
You need to get yourself a manual. A Bentley is best, if u cant get a T3 one they have reprinted beetle ones which should be useful to you. Or a Haines and the Idiot manual by John Muir is a good read.
Your shoes maybe worn too outa round to save em.
But try this
Jack rear up. Undo handbrake cables in cab. Wind adjusting stars up firm/tight. Pump brakes a few times. Wind adjusting stars out till just touching drum. Re adjust handbrake cables so they pull evenly on both sides.
Have a cup of tea.
SummerBus ·
She looks amazing dumped on her arse and the new shoes set her off beautifully.Well done,looking forward to the progress shots.
izac ·
Thanks Choppa will give that a go tomorrow and see what happens. youre right, i do need to get myself a manual 🤓 cup of tea sounds good alsochoppa wrote:Your shoes maybe worn too outa round to save em.
But try this
Have a cup of tea.
izac ·
wire brushed and sanded it down a bit and slapped a bit of this stuff on it...
and some bright red Bristol Stop Rust that my dad has had sitting around for years, and it is a big improvement!!
pretty in your face but i like it 😀 planning to get some carpet soon anyway 😉
looks a lot better than this
i think its happy with its new coat, been waiting a long time
izac ·
came today from Busnbug, thanks Brad.
put it in for a test fit this afternoon before i put the underlay in and stick it all down..
Peter_D_C ·
Nice one izac. Got carpet in mine last week as well. Installed a stereo too after much pain and swearing.... Never again.
izac ·
how did you do yours?
Peter_D_C ·
Bought what i though was an original accessory radio holder thingy that was meant to bolt into the dash. It must have been for an earlier or later model cause it didnt fit, so had to trim it a little.
6x9's with spacers in the rear under the back seat, 6"s on the kickboards. Goes alright. Be sure to put your wires in before carpeting!
Burgo ·
Burgo ·
izac ·
yeah load of awesome crap that is 😂Burgo wrote:what a load of crap... LOL im kidding man, looking great! should get like flames on it i reckon haha
thanks man, but no flames for Miles only patina..
yours is looking good aswell, can't wait to race ya haha
peace out
Wannavee ·
izac ·
bought a 2m square of 10mil thick felt for about 50 bucks, and cut it out to the countours of the floorpan, tunnel, front and rear kick boards,
and rear cargo area. acts as a cushioning for the carpet and hopefully sound insulation (to replace the old tarboard) as it is very dense.... would have liked to have done it in one big piece (better insualtion) but it was too thick to bend tightly around the corners
2 meters gave me more than enough, still to do rear firewall (behind back seat)
here are some pics
trickysimon ·
Has the underlay made a noticeable difference?
colonel mustard ·
matara ·
Looking excellent though
izac ·
you can see those clear bullet lenses you sold me, cheers 👍
trickysimon, yeah the underlay does seem to make a fair difference especially now i have it in the boot.
colonel mustard ·
I think I've got the image to work, Thanks Izac. Your not just a drummer... hahaha
izac ·
izac ·
They are 36 Dellorto Drla's. I have ordered the CB short manifolds and linkage kit which should be here soon and some smaller 28mm venturis and a Delllorto handbook which should hopefully help me out.
I am pulling the engine out this week doing a bit each afternoon after work. I got the car up on stands at the rear and and ramps up fornt today. But I have realised that my trolley jack wont reach high enough to the engine. a
what can i do? any ideas?
will post some pics tomorrow
colonel mustard ·
As for the jack - just use your brain and do it safe 🙂
izac ·
nearly slipped off the jack at one point!
[img][img]
colonel mustard ·
izac ·
no worries man, nah im not going to easterfest...
anyway atleast its out now so i can get those dells on here are some more pics
colonel mustard ·
Good luck with it all. You are pretty brave to just go for it. 🙂
Mick058 ·
Get yourself some wood chocks and make sure you support the car on more than just the jack! Axles stands are good and cheap too.
izac ·
Thanks Mick, yeah i have the axle stands under the rear torsion housings and the front wheels are chocked on ramps.... it seems pretty sturdy but it is scary when you think about the angle it is on...🤓
colonel mustard ·
I think I like the idea of these - http://www.thesamba.com/vw/classifieds/detail.php?id=731616
(40's)
With this kit (type one duh!) - https://secure.cbperformance.com/catalog.asp?productid=537 (is it the one you got???)
Oh, might be nice on a Rod penrose 1916....
Trickysimon's new engine.... it looks awesome, and will be interested to see how much it puts out
Ah, If only I could afford that. I would totally race at warwick. 🙂
izac ·
keep saving man and one day you will be able to do it... but i admire what you are doing with your time and money (lack of 😂) right now keep at it and you will be rewarded!
izac ·
gave the heads and spark plugs a bit of a clean and then covered the ports... started painting the tinware aswell (the all imposrtant bit 😂)
now just have to get the manifold kit in the mail and bolt em on, should be sweet 👍 something will probably be wrong along the track as always but thats half the fun haha
took some pics but am not able upload them for some strange reason. will take some more with the other camera and put them up soon😎
colonel mustard ·
Thanks for your previous comment, I appreciate it. Its actually kinda tough finacially at the moment, but my job starts soon, so hopefully get it going well. YMIS is the sweetest course ever. 🙂
izac ·
yeah ovi is crap now... i have changed to using photobucket now. yeah i cant find the guage so i havent measured the clearances yet, might have to buy a new one.
you dont need a big $$ engine to race at vallacolonel mustard wrote:Ah, If only I could afford that. I would totally race at warwick. 🙂
hell, team china proved that one
1x free beetle and 1x $50 unknown 6 volt 1300 engine
as they put it so elegantly: fun for under $500 LOL
Even Steves young bloke had a blast in there stock 1600 Lbug
colonel mustard ·
izac ·
and with some of the tin ware on.. gave the case a clean with some oven degrease and kero and looks a lot better.
izac ·
colonel mustard ·
izac ·
got the parts yesterday! o h yeah now the fun begins... 😎 i love parts stashes
started a mock up of carbs on the manifolds on one side of engine...
do i locktite these studs to the manifolds or what?
the throttle shaft spring/ butterfly opener mechanism was just catching on the manifold so had to do some clearancing with the file...
went to test fit tops and air filters but there is a thing sticking up that stops the air cleaner base plate from sitting down flat...
cant see it in the dellorto tech book.. does anyone know what its for? or hjow i can get it off?
colonel mustard ·
izac ·
changed the venturis over to 28mm from 32mm and set idle and mixture control so hopefully the jetting will be ok
regarding the chokes i dismantled them and then screwed the cover piece back on seperately to cover the hole
matara ·
izac ·
Peter_D_C ·
izac ·
Why would you do that?? 🤪izac wrote:changed the venturis over to 28mm from 32mm
colonel mustard ·
izac ·
i think there is more chance it will run smoother with the 28mm vents rather than the 32's as it is only a stock engine with the stock cam. we'll see how it goes and if it is too tame i might switch to the 32s then..Bizarre wrote:Why would you do that?? 🤪izac wrote:changed the venturis over to 28mm from 32mm
what do you think?
colonel mustard ·
colonel mustard ·
izac ·
nup 🙅colonel mustard wrote:Also, do you ever wear closed in shoes.....:S
colonel mustard ·
Its looking awesome mate. I started target this week... so carbies on the list of things to do. Need to get my guitar serviced before i go north next month. Normanton here i come... 🙂
izac ·
really??colonel mustard wrote:cause its a 1500....
I would have thought a 1500 was a single port??
izac ·
izac ·
the carbs are setup at the moment with 28mm venturis, 180 Main/air, 135 Main/Gas, 52 Idle Gas, 33 Acc/Pump.
does this formula sound alright for a mostly sock 1600?
here is the engine ready to go back in..
also what do i do with this pipe coming from the oil filler that originally went to the oil bath air cleaner?
fuel lines done
is this fuel filter suitable?
blocked off the right side double banjo with a screw with a piece of fuel hose and a hose clamp..
planning to put it back in tomorrow so we'll see how it goes!
colonel mustard ·
Is that fuel line the same as the original??? I much prefer the genuine stuff.... i think it lasts longer... If the filter ends fit in the lines.... your all sweet. that filter is from a carby laser/323 🙂
looks good. why dont you paint your exhaust while its out?
matara ·
Looking good
colonel mustard ·
Izac, you could put a breather box off the oil line... Of a breather of some kind. Don't block it off.
I can probs get you one second hand for cheap...
If is also Jon from ACnet's opionin as well
1600 Option - http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=FSK0020&cartid=
"We will configure your dual 40 or 44 IDFs for optimum use. We change the venturis to 32mm, and rejet the idle, main, and air jets for this price"
For some reason others promote 28 in there but i have never seen a set run properly set up that way
Main should be 4 to 4.2 x the venturi size
so .........
28 = 115 main
32 = 130-135 main
Airs - add 50-60 to this
Idles is what your engine wants
My webers wanted 45's
Personally i reckon 52's is a tad big - when you find "best lean" you wont turn out as far.
See how that goes - maybe the idles wont block up as much as mine did
So - your jets are set up for 32 venturis not 28's
You should either change back or get some different main jets and air jets
Have a read here as well
http://www.aircooled.net/gnrlsite/resource/articles/jetting.htm
Get your self a goos synrcometer as well
like the "new style" one listed here
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=TZE0021&cartid=0417200931841716
then read here
http://www.aircooled.net/gnrlsite/resource/articles/dualcarb.htm
Have fun
izac ·
i am considering changing the vents back to 32s before i put it in... so you dont think 32s with this jetting combo will be to much for the little whippersnapper do you?
thanks Steve, i will pur some zip ties round the fuel lines if thats what you mean..
izac ·
colonel mustard ·
this is what im going to have for my oil breather setup ..... im going a bit different to usual, its not going to vent the tappet covers, just from the filler and one air cleaner.... cheap and easy 🙂
not at all - i ran that exact set up on a 1600 and a 1776 with excellent economu and performanceizac wrote:thanks for your help Bizzare
izac ·
i got the engine in this afternoon but will have to wait for tomorrow to get it running - ran out of time and was feeling pretty lousy.
didnt take any pics coz my camera is out of batteries, but the air cleaners are ridiculously tight fit... i knew they would be tight but not this tight!! one side is literally touching the engine bay metal!! will this cause damage with vibration etc..?
izac ·
i wired everything back up and went to turn the the key and...nothing. 🙅 the lights dont come on or anything and pressing the button does nothing of course.
im sure its wired up correctly. i took note of how it was before i took it out. red wire to generator on upper + terminal and green wire below. green wire connector has only got half a connector on the end though (has been broken so is a bit loose but there is contact).
is it possible that the battery has gone dead while ive had the motor out?
please help
izac ·
you can see how tight the dells are in there...
izac ·
izac ·
colonel mustard ·
probs zip tie the old choke leads out of the way. not a good idea to cut them... :| or you could just remove them all together....
matara ·
izac ·
thought i had a flat battery but then i found i can get a spark from it... so not sure what the problem is but there is nothing when i turn the key... what a downer 🙅
matara ·
izac ·
izac ·
colonel mustard ·
Burrelli ·
izac ·
Hi BurelliBurrelli wrote:Hi.. If you have trouble with the carbs hitting the body, try shimming the rubber mounts on the subframe. They settle in over the years and the engine moves up in the engine bay.
That sounds good but im not exactly sure what you mean (where are the rubber mounts?). I would have thought shimming them would make it higher but thats probably cause im not sure where they are...
Burrelli ·
The Subframe is the tortion bar housing and forks that your engine and trans bolts into. On a type 3 it is rubber mounted to the floor pan and not welded like a type 1. It is mounted at 3 points, over the years the rubbers deform (on a swing axle car especially) and the subframe, engine, trans all move up closer to the hatch and load floor. I don,t know where originally it all should sit but some shims (big washers) underneath the 2 back ones, just enough to get some clearance for your air cleaners should be OK.
izac ·
Burrelli ·
izac ·
izac ·
It just cranks over...??
not sure why this is but is annoying because it was running...
izac ·
got one thanks to Simon (volumex on here) 👍
have to decie to whether to keep it rat looker or get both apron and bonnet painted under insurance
colonel mustard ·
DU88EN ·
DaveCarter ·
Scarab ·
sorry bro, just thought I'd give you a bit of encouragement...your square is looking real nice....good work with your carb conversion too mate, does it go a fair bit harder now?
izac ·
yeah it sure goes a lot harder with the carbs. lot of fun to drive 😁
Scarab ·
I just love the early style type 3's.....in fact I am already looking for a square as well......but no real hurry for that one 😀
There is plenty to do on mine before I need another one!
izac ·
I wouldn't mind a Notch too. Maybe one day 😂 but one old car is enough time and money for me at the moment 😵
If you plan on lowering yours, I would suggest modifying the bump stops on the front beam as you will find it will be a very bumpy ride if you dont. In my opinion they handle a lot better when they are lowered (and look sweet of course!) especially if you have the right tyres/wheel offset on the front.
Scarab ·
the future plans entail dropping it quite a bit further. Thanks for the heads up on the bump stops though mate!
I have been reading a lot about lowering on the UK Restocal site, http://www.restowagenuk.com/forums.html
if you haven't checked out that site before...do yourself a favour, they have some SWEET rides!
some of those guys run their cars unbelieveably low!!.....looks good but! 😂👍
Doctor ·
bugking ·
Scarab ·
Short axles in yet???
izac ·
I just got some new tyres on the front yesterday which I'm really happy with. They are Kumho KH11 Ecsta 155/60R15 - got them from Brendon at F1 Wheel and Tyre on the Gold Coast for $119 each if anyone wants some. They are loads better than the 135's with more rubber on the bitumen and smaller profile so no rubbing and look sweet!
will get some pics
izac ·
Mick058 ·
Scarab ·
Sorry to keep busting your chops on the short axle thing, but I'm hoping you will work the kinks out for me, so I can do it easily 😂 Please load as many photos as possible etc....
So what axles are you planning on using....sorry if I missed it in an earlier post or something....I just want to know what I need to be on the lookout for my project Notch.
Pulled the seats and carpet out last weekend, and guess what I saw???......the driveway!!! 👎 major rust in the rear footwells, bit bummed about it really....but all the more incentive to pull it apart and do a proper job 😂
So, quit your job eh?? whats up with that? Not happy? do you have another one to go to? Hope so mate, otherwise you won't have any cash to spend on the square! 😢
Cylon ·
Hi Izac,izac wrote:picked up some of these yesterday
Wondering what you are doing with these centre caps? i dont think these are for a BRM, are interested in parting with them ?
Car looks great need any bits?
izac ·
Yeah those centre caps don;t fit the BRM's without a spacer - so not planning to use them. Just gonna roll without caps, adds to the rat look me thinks 👍Cylon wrote:Hi Izac,izac wrote:picked up some of these yesterday
Where abouts are you mate? You can have if you want em.
Only parts I need at the moment are the short axles and tubes.
Cylon ·
izac ·
Planning to use axles and tubes out of a pre 67 ? beetle which had the short ones.
Yeah mate I found a whole lotta bitumen staring up at me when I pulled the carpet to! 😵 sounds like its time for some new metal to weld in (see page 1 of this thread for pics of pan 🙄 - cleaned up alright though).
Scarab ·
What are you studying (if you dont mind me asking) Hope all goes well for you mate, all the best!
izac ·
bugking ·
izac ·
Scarab ·
I would be really interested to hear what is involved with your course and how it all goes for you mate.
All the best!
PS: Get cracking on those axles bro! 😂
izac ·
I appreciate the support and your interest will let you know how its going. the course starts in october.
have to get those axles done before that and have a youth camp coming up in a week and a bit, so really have to get it all knocked over this week. writing up the 'to-do' list right now! 😉
izac ·
never done itt before and was confused by the Idiots guide as it says it should be right in front of the where the engine joins the trans?? i need to find a picture of it... 🤓
Scarab ·
Sorry I can't help with the shift rod coupling, I haven't got a clue either....I'm letting you work out the kinks remember 😁
All the best mate....and don't forget to take pictures! Cheers!!
Scarab ·
A small suggestion for you....get someone to operate the gearlever for you from inside the car while you are watching at the back, this would surely give you an idea of what you are looking for when you see something moving at the transmission end. (I guess that this would be the case, but as I haven't actually done it or seen it done as yet, I am only guessing).
Hope it goes OK for you mate
Paul
izac ·
trans is out finally! only took me 3 hours!! 🙅
now to get those short axles and tubes and get everything machined.
Scarab ·
good luck with the machining mate, hope all goes well.
Nickster ·
Nice work izac....love the carpet too.
So who's 'Ronnie', I'd love a set of BRMs for my '62 Bug, and just over a $1k sounds like good bang for yer buck!
Where in Brissie are you?
Nick
izac ·
Ronnie is a guy who lives on the gold coast and sells vw and hot rod parts on ebay. this is his ebay store http://shop.ebay.com.au/6730/m.html?_nkw=&_armrs=1&_from=&_ipg=
but it doesn't look like he's got any for sale at the moment.
but found this store that sells them
http://shop.ebay.com.au/uniquewheelscomau/m.html?_nkw=&_armrs=1&_from=&_ipg=
looks alright 👍
Nickster ·
colonel mustard ·
Scarab ·
How did the machining go on the axles etc. Interested to hear how its all progressing....did you take any photos?
I'm genuinely excited to see how the square looks with a full set of BRMs on it! I am sure you are too Izac!! 😀
colonel mustard ·
Izac had got the new axles in and the rear hubs back on. His drums were off for machining.
should be done by the end of next week I think. 🙂 just a few things to hook back up (clutch cable, throttle cable, throttle linkage, hand brake line, rear brake line, engine bay eletrical, breather lines, fuel lines + CLAMPSSSS!!!!) , and a few leaks to fix...... woooo.
The new tires look sick on the front, And I think I have changed my mind back to BRM's... 🙂
Scarab ·
Keep up the good work guys.....the fiddly things always seem to add up when putting things back together, just knock em off one by one and they'll be done in no time.
izac ·
went to pull backing plates off to have a look what was going on and the O-ring seal was broken, so have to get some new seal sets, learn how to install it properly and try again.
trickysimon ·
izac ·
colonel mustard ·
izac ·
looks like i might need some of those 90* breather fittings, i can't get the hose to fit!
got my drums back today and bought 2 more seal kits and a VWMA mag so hopefully will give the backing plates another crack tomorrow morning.
colonel mustard ·
90* fittings. good idea.
izac ·
yeah but where do you get them from???
colonel mustard ·
i got a large tee for breather hose, it was made of plastic. its probs possible to get them in 90*'s
izac ·
colonel mustard ·
Doctor ·
Thats an awesome ride height, how many splines front and rear?izac wrote:
izac ·
Doctor ·
Awesome, basically the same as what i was planning for mine, except now im going the same height as yours in the front, i was planning on 2 in the front, but that looks awesome...izac wrote:thanks man. i think i went 3 outers in the front and 2 inner splines in the back.
colonel mustard ·
izac ·
well its rolling now... and looks pretty sweet. got the new seals in etc. and put drums back on then plonked it down on the Brms 😎
the only thing is, I broke the 2 steel brake hoses coming from the backing plates and can't unscrew the broken piece where it connects to the rubber line. so I am not able to connect the new steel lines up 😠 not sure how im gonna get them off...
will post pics tomorrow
colonel mustard ·
izac ·
hose doctor.... sounds interesting. 😏
colonel mustard ·
izac ·
probably will get body work done week after next as I am going away next week.
thanks man
colonel mustard ·
Scarab ·
by the sounds of it, you've got the majority done and the BRMs on....well done. How did you break the brake pipe, was it a seized fitting or something????
hope all is going OK for you.
you and Colonel sound like you are good mates, its great having mates that are interested in the same stuff as you, well done guys......keep V Dubbin'it!
colonel mustard ·
hard at work....
ewwww... leaky... 🙁
hotness...
ratlook? yeah boy...
tool to fill the gearbox oil....
dellorto's and thunderbird.... 🙂
sad damage....
love those BRM's
engine back in..
izac ·
my dreads don't help my case either 😂
nice pics by the way man
Scarab ·
Well done guys....is it driveable yet? ....im hanging out for some pics with the full set of BRMs on.......waiting, waiting, waiting......😂
izac ·
not quite driveable yet, planning to spend a whole day on it tomorrow so will let you know how i go. hopefully i'll get it finished! 😵💫
colonel mustard ·
Doctor ·
Thats exactly how i work on my cars! And how i spend almost every day, boardshorts, t-shirt and thongs.... Usually with some dark sunglasses and a camera on me as well though....
On a side note... your aircleaner setup... can that be run on standard carbies or do you need other ones?
izac ·
izac ·
a pic of what brisbane looked like yesterday
and one of today 😀
Scarab ·
At least they are on there mate, well done!!
Perhaps try getting it out of the shed next time you are gonna do a photo shoot 😂
izac ·
about to go and bleed the brakes now, be back soon
colonel mustard ·
then take it outside and get a full shot of the BRMS!!!!
yay, nearly there man 🙂
colonel mustard ·
izac ·
was so close to getting it finished!!! dad helped me to undo the broken brake lines so that was good.
only a few more things to do, so hopefully today is the day.
colonel mustard ·
Scarab ·
izac ·
got the engine up and going! sounds fantastic 👍
and got everything pretty much done and was able to back it up to park it at end of garage... wasnt expecting the clutch to work! 😀
plans for tomorrow are - bleed brakes (front ones this time hopefully), then check all connections and bolts/hoses etc, tune up and then PHOTOS!!!
hopefully everything will be sweet so I can drive up to camp at the sunshine coast on Sunday!
and hopefully the 'modified' are cleaners will run alright... planning to get some new ones like this soon though.
http://www.lynxcorp.com.au/shopping/occ/productimages/RF640S.jpg
photo's tomorrow!!
gsa2at ·
good to see you doing the work in yor safety boots
if you are coming up the sunny coast let us know by pm - we';d love to see the square in in the flesh
Scarab ·
have a good day and hope all goes smooth!
izac ·
gsa2at, I will be at Alex heads for the week as a volunteer on a youth camp so won't get much time to get out unfortunately. where abouts on the coast are you? would be cool to bump into each other though - if you see the square definitely come say hello 👍
Jack is looking great by the way, when is rego planned?
izac ·
no sunshine coast rip for this one tomorrow though few issues with engine unfortunately, was downstairs til 7:30pm tonight trying to sort it out. so close, but not quite safe enough to make the trip 🙄
Scarab ·
that square is ROCKIN' !! seriously cool, are you happy with the results mate? the stance looks great, the clearance on the rear looks spot on, and that little bit of camber.....LOVE IT!!
have a great time on camp bro....you deserve to have a few days away with all the work you put in on the square this week, well done 👍👍
donovan ·
theres plenty to do on mine!!!!!!!!!!
izac ·
thanks man - have ordered some new parts so hopefully when i get back from camp i can get it going again!
talk to you in a weeks time!
Scarab ·
DaveCarter ·
mister_e ·
Doctor ·
Any tips on lowering, i plan on doing mine in the next few weeks...
Scarab ·
try this link......
hope that works for you, if not, go to you tube and type in lowering type 3 vw, that should get you where you need to be....low and scrapin 😂
Scarab (aka:Paul)
Doctor ·
colonel mustard ·
Doctor ·
izac ·
Doctor ·
Should be doing it next Saturday at my mates place... See how things go, but fingers crossed it should be done!
izac ·
you might find there is a piece of metal pretruding from the the front beam that might stop you from going any lower. this needs to be modified with a grinder if you want to go lower.
Scarab ·
All the best mate,
Paul
izac ·
thanks for asking man.
Scarab ·
Good on you mate, you will be rewarded for your efforts!! 👍
colonel mustard ·
izac ·
Made some slow progress today - found it was only firing on 3 cylinders (which explains the fuel leaking out of no. 2 exhaust port) so spent most of the day chasing new leads and the like. But finally managed to get the plug out and it is pretty black and oiled so hopefully if i clean it up it will fix it.
These came this morning 😀 and fitted perfectly! no more clearance issues.
hopefully more progress tomorrow.
colonel mustard ·
Scarab ·
Peter_D_C ·
Do thos ramflos fit on the CB performance aircleaner base or do they come with their own base? You're running dells from memory yeah?
Hopefully my sqr will be back on the road within the week - with a Pobjoy 1916 in the back 😵💫
izac ·
hell yeah man! thats sweet! 😎Peter_D_C wrote:Izac,
yeah they actually fit on the CB bases which is really good so i can still use the same linkage. they do come with their own bases also. highly reccomend them man - revs a good 500- 1000 rpm higher now...🥷
Scarab ·
The axles have been done for a couple of weeks now, have you found any issues/problems or is everything AOK?
Catch ya mate,
Paul
izac ·
the axle tubes have been leaking like crazy and the brakes are shocking among other problems.
Its in at Phoenix engineering at the moment getting the brakes redone - new rear wheel cylinders, rehoned front wheel cylinders, new shoes, etc etc...
not gonna be cheap.. but hopefully they will sort out everything, they also told me the axles were leaking because there were no 'outer axle sleeves' on. so that should fix it 😉
colonel mustard ·
Scarab ·
what sleeves are they talking about on the axles, is it a seal or something on the end?
all the best mate,
Paul
izac ·
trickysimon ·
Scarab ·
Paul
colonel mustard ·
izac ·
😂 i would of if i had them but i can't remember seeing them there in the first place 🤪trickysimon wrote:Why didn't you put them back on?
no not trying to save weight 😂
colonel mustard ·
izac ·
colonel mustard ·
still taking it with you? or is there a few $$'s left over for a car cover, a good carwash and some timeout in the garage while your away?
izac ·
empi ·
izac ·
izac ·
the brakes should be good now after spending the last week at phoenix but don;t know what the bill is goona be yet! 🤓
trickysimon ·
izac ·
trickysimon ·
izac ·
colonel mustard ·
izac ·
$900 😵
colonel mustard ·
izac ·
heres what I had to have done:
Check brakes allround
New rear wheel cylinders
Recondition all four front wheel cylinders
New front and rear shoes
New gear rod coupling
New axle seals
Bleed and adjust brakes
Peter_D_C ·
Scarab ·
at least you will be confident in braking hard if some knucklehead pulls out in front of Miles.👍
izac ·
man check out that front apron mmmm
izac ·
pete, you weren't happy with the price? what happened?
the ramflo's are 400 cfm's by the way.
Doctor ·
trickysimon ·
colonel mustard ·
Hows things Izac. hit me up with a message some time. Not on FB though... oh yeah.
Scarab ·
Doctor ·
colonel mustard ·
izac ·
colonel mustard ·
Any time you feel like a cruise hit me up, and we'll go for a drive.
Scarab ·
Scarab (aka: Paul)
izac ·
Im in Peru at the moment so my sister is looking after it for me while Im a way... shes still on her L´s. But she took it to custrom veedub and Pete fixed up the air leak in the manifolds so I hear its going pretty strong! I miss it over here! And my dad is also building it a carport! 👍😎
Theres so many VWs over her in Cusco! Id say about 40% of the cars here are Bugs!
Heres a couple of dodgy photos I took out of the bus today... i always see this sweet Dual Cab Split ute when we go into town so i tried to get a pic of it but people were standing in the way! Its a sweet bus though 😵
Scarab ·
Glad to hear Miles is in good hands too!
All the best mate,
Paul
