Aussieveedubbers 路 Members Rides
My notchback 72
https://forums.aussieveedubbers.com/threads/69923/my-notchback-72
notch-72 路
ok so heres my project,I've allways loved Vw's allways will currently own a 94 vr6 (forsale)but fell in love with the type 3's after vw day 07.so i came across this ripper and had to buy it,ill post another lot in a couple of months.
this is how i brought it looks (looked) ruff i know.
original back
original door trims stuffed!
new door trims
subbox
stage one of back set up.
Dynamat will be going every where have used 8 sheets so far will need another 8 covering every possible part i can on the inside.
its only surface rust.
All surface rust removed
new back shelf
half the gear that will be going in car
trickysimon 路
This should be an awesome ride when finished 馃榾 Is there gunna be any back seats at all or is it all sound system?
Simon
notch-72 路
Cheers, yes there will be two seats in the back each side of the subwoofer custom made.things to be done .
1.Full custom leather interior (still not sure on colour)
2.Stereo system.(from speakers,t.v's,nintendo,custom i-pod holder,l.e.d lighting,and more.)
3.All old rubbers replaced.new steering wheel
4.Dropped on its guts.
5.New white wall tyres
All hopefully done for vw day 08.
type3kid 路
keep pics coming dude, looks mad!!
notch-72 路
cheers mate,At this stage its very dual but getting there, will keep the pics coming once something new happens.
getting quotes for interior shortly,Cant wait !
pete wood 路
you might want to look into converting to a decent alternator. 馃槈
BTW, love the notch. I hope you're planning on a engine to help drown out some of that install. 馃
notch-72 路
Yes very good point !
Are most alternators the same size? whats a real powerfull one that will fit into my notch?
As for the Engine at this stage it has a 87mm big bore kit.
Yes there will be plans for more power in the near future.
are there any other things i should be doing before the big stereo goes in?
i want to do it all one time only.and to the best i can.
notch-72 路
Just finished getting the front seats and back seats custom fitted, thanks alot dad.Note all welds will be finished of to perfection and im not using thoes long bolts,just there to hold in place till i get correct bolts.
Not sure what to put under subbox to fill that gap,not going with what I originally had planned.
Goes up and down like it was allways there.
some of my fathers work close up,bracket for back seat.
closer look.welds will be finished better.
Seat on the right was the original size they came from a daewoo and needed a massive downsize to fit.
This is the mount for the front seats, was welded to the door sides on top of oringinal brackets.
Under View
Top View
Front seat inside brackets.
Original seat.
Down size to fit.
Dad also made a custom white ball gear knob.
Next Is Paint.I had Planned for candy Green, but now thinking just a simple original colour,With an out there interior colour.not to sure.....Any suggestions.
squizy 路
Our real own Pimp My Ride, here on AVD. Nice start.
Fatso 路
Nice work there!
Euro_67 路
Your Dad is quite the fabricator, tidy work.
Why the fold down seat backs ?
notch-72 路
Cheers squizy,Fatso,Euro_67. ,Yes if it wasnt for my dad the car would still be the same, i got the ideas he makes it happen.I plan to make a notchback like no other,fold down seats are there so i can work on the amps ,sub amp will be behind one and other side will be the 4 channel amp not on the doors them self, if your looking from the boot you wont see any of this as im having it all hidden from the boot view.so thats the main reason for fold down seats plus its different.
