well i'm beat i cant get the thing to idel driving along minding my own and maybe others peoples business when next i stoped at a set of lights the stupid thing just will not idel and gets the hops when ya off the go pedal and lightly back on
took the carby off removed all bits blew out with compressor back to gether and back on after making sure all was as i should be
started up and bloody wont idel y oh y save me from these water things there possessed evil i tell ya 馃槧馃馃馃
pod 路
Steve has it got an idle solenoid???
you can always give it to me and i`ll fix it up and take care of it馃榾
greedy53 路
oh you mite be onto something there i'll look just before i shoot it between the lights water cooled it's not natural
no had a look no idel electric thingie so back to the book 馃お
Iwish4aSynchro 路
If idle is hunting the gaskets it be.
If idle is dying then electrics it be.
All other avenues are hit and miss.
Good luck
Sounds like it's pulling in air from somewhere.
greedy53 路
ok somewhere to start it will rev to 10000000 rpm but the dam thing just wont idel and it just started no warning stop at lights no idel
water it's not natural witch crakt i tell ya
polarbus93 路
steve take a look at the hoses leading into the carbie if they are brittle air will get in did you check that the needle and set are clean soak them and try again
Iwish4aSynchro 路
OK Buddy.
So whilst under load it wont rev? Yeh?
Ok check air intake valve at carbie?
Make sure Carb intake Gasket is good and seated.
Bit like a Bike small things make a big difference with these one.
thanks all still won't idel this started while i was cruising down the road no probs then next set of stop light no idel no clunks or bangs or up ya bro just no idel
i think my wife has an answer i'll just break down and cry in public seems to work for her
greedy53 路
ok turns out the rotten mixture screw was a dud striped so no adjustment took me an hour to get it out totally striped so a new or really good used carby is the go anyone know where i may get one it's a solex 34 pic 5 the one with the water choke
thanks
polarbus93 路
steve the wreckers on the northen road cranebrook on way to windsor has two mk1 if you want ill go have a look in the morning let me know todd
greedy53 路
thank you i will be scampering out sunday
Iwish4aSynchro 路
Crying always helps馃槀
Just get some photos of actual breakdown momnet for future reference so when u next venture into Water cooled territory you can be reminded.
Good Luck馃憤
greedy53 路
what the terror at night about owning more water cooled things isn't enough
polarbus93 路
the problem isn't within the water it's in the fuel (ha ha) just remember everybody is 70% water but most are full of hot air....
greedy53 路
i like that it's better than what i'm told i'm 90% full of
polarbus93 路
nver believe everything your told !! but then again i work for the government so ?
Iwish4aSynchro 路
Oohh a spy馃槀
polarbus93 路
no just sometimes i can't remember what true or whats fabricated truth
pod 路
polarbus93 wrote:nver believe everything your told !! but then again i work for the government so ?
When did you ever work馃槀 i thought you got appearance money馃憤
polarbus93 路
ok so that only proves one mis dermeander
Iwish4aSynchro 路
damm, has this thread been hijacked into a bashing of polarbus?
I dont really know the bloke but what the hey.
this appearance money one speaks of how does one obtain such a position?
And the appearances are they random or planned. I mean does lurking in the bushes count as an appearance?
polarbus93 路
training for three months helps but you must leave your mind and ideas at the door .... but ive aways said out of all the things ive lost i miss my mind the most.. !
greedy53 路
i think i found it it's a bit dirty now that i've used it sorry
polarbus93 路
cool!!!!!how did you go is the waterpumper pumping fuel yet?
greedy53 路
soon with a bit of help from friends
pod 路
Iwish4aSynchro wrote:damm, has this thread been hijacked into a bashing of polarbus?
its ok we know him unfortunately馃槀馃槝
polarbus93 路
sorry pod it's ok if you don't want to talk to me either 馃槩馃ゲ
