Type 3 Indicators not working
https://forums.aussieveedubbers.com/threads/69994/type-3-indicators-not-working
bitemeoz ·
hi all, my indicators have stopped working. when i click the turn signal it just stays on doesnt click on/off and the indicators are not working at all. So is it just the indicator switch/unit that i need to change?
John
bitemeoz ·
anyone?
Midlife crisis ·
if the indicator arm feels good not loose or over tight then I would look at the flasher unit.
Are all the bulbs ok?
Marc
greedy53 ·
first check all earth wires just because the emeregency flashers work does not mean the blinkers work thee earth in the unit on the wheel seems to be the dud so i would start there u may need to pull the wheel off to have a look
other than that i would try another can first i my memory serves me right there is a wire from the can to an earth
well check all earths
good luck
