running lean
https://forums.aussieveedubbers.com/threads/70068/running-lean
bigdood2 ·
Hi Guys,
I need some expert opinions.
Can anyone tell me exactly what the bypass and volume screws do on a standard 75L Bug carby,I want to try running a bit leaner to get better fuel economy,I've followed the manual but it does'nt actually say if clockwise is leaner or richer,and inside the tailpipes looks a bit black(rich) .
Also can running leaner do damage?
Go roosters !!!!!!!
yes - running lean can be bad.
Lean = hot = damage
Regardless
in is lean
out richens
you should have a 34 Pict 3 carb onyour car
tune by this procedure
http://www.vw-resource.com/34pict3.html
If you are really keen - get your car dyno'd or at least get an analyzer put on your tail pipe
donn ·
Best economy is tuned spot on, not lean, not rich. If the motor is tuned to its optimum then it is giving the most power available from a given measure of fuel, least thats the way I see it.
ancientbugger ·
Also I don't think the colour of the exhaust pipes makes much difference since leaded fuel went out of the window.
