I have a 1500 box to go in front of a 1600 twinport that has a 6v flywheel on it. Therefore i must use a 6v starter.
Box has 12v starter bush, If I remove bush & drill hole to match 6v bush (Backyard job) I'm worried about the chances of the drill going through true.
My other thought is to get the starter armature machined on the end to match 12v bush. I assume it would then need some surface treatment (hardening) Would this be possible just on the bit that has been machined or would I risk the heat destroying the armature windings?
I don't want to replace flywheel.
Regards,
Matt.
Matt Ryan ·
