Engine Case salvagable?
https://forums.aussieveedubbers.com/threads/70114/engine-case-salvagable
silver ·
Hi all I have a pulled head stud (10mm) in an old 1600 sp case What I want to know is can I have case savers fitted to it and run 8mm studs seems feasible. but is it possible ? with all the knowledge here I can rely on good answers
come back good buddies
silver
dangerous ·
Yes that is possible and popular.
That being said..
if it has pulled a head stud it may need other work also.
(crack check, line bore, deck barrel face etc)
You may be able to find a stud with an oversized self-cutting thread at one end - they used to be sold at VW shops to 'fix' this problem. Not sure where, though, as I have never used one
silver ·
VWCOOL wrote:You may be able to find a stud with an oversized self-cutting thread at one end - they used to be sold at VW shops to 'fix' this problem. Not sure where, though, as I have never used one
That sounds the answer, for this case anyway
any one know more bout these?
Silver
silver ·
Okay found them here's the page
http://www.dansperformanceparts.com/buggy/epc/buggyep%201%20case.htm
while reading the description I realized I already had one in it
Thought it was a strange stud
I also found on the same page case savers 14mm od they should solve it
an easy tapping job then
heres a pic of mine and the damage
dangerous ·
You can get 12mm ones and also 1/2inch and 14mm.
And you could make any size you wanted if you had to.
I would go 12mm or 1/2", that way you have options later
and can still bore for larger cylinders if you ever wanted to, without hitting thread.
xornge666x ·
BME in Dandenong used to have them... now bought out by Unique Auto Parts / Mercwreck
I think they are still using the same number as BME
03 9791 1822
22 Lanyon St Dandenong Vic
Give Boris a call 9789-1777
matara ·
Silver,
I have an German NOS 1600SP ex-industrial 126 case that had 16 hours service that you can have for $200. This does have 10mm studs and small 8mm oil galleries, but perfectly suited to a 1600SP application (just not the right case for a hot engine). You'd need to put your internals into it, but at least you'll know its not had a regrind and is factory tolerance.
Hi Ho Sliver
Mataras offer sounds like a a good idea. All the single port cases seem to have a more fragile alloy than the later cases, you will get this problem fixed and another one will strip soon after.
dangerous ·
matara wrote:Silver,
Boy!
That has to be the deal of the century.
Excellent value and a sold base for many miles to come.
