Where can I get Patina Aging Compound
https://forums.aussieveedubbers.com/threads/70145/where-can-i-get-patina-aging-compound
VWFREAK ·
I've looked everywhere after seeing this stuff in Volks World.
Great stuff you can turn an average car into a rat with a little elbow grease.
Anyone?
Thanks in advance.
greedy53 ·
i know you are gonna think i have lost it again or maybe you know i lost it but
oraange or lemon juice will give you that flakey rust look just bare the metal and rub on leave overnight and walla patena
pod ·
piece of wet and dry maybe??
greedy53 ·
make up ya mind wet or dry
VWFREAK ·
Thanks guys, but this product will actually do all the hard work and crack / marble the paint as well.
Anyone
LUFTMEISTER ·
sunlight.......free everyday😀
byronbus ·
April fools
byronbus ·
The before pic isnt a barny, pretty good if it changes a later bus into an earlier one... he's taking the piss
squizy ·
Ha ha Brucie.
hewey ·
Bone Collector wrote:Thanks guys, but this product will actually do all the hard work and crack / marble the paint as well.
Anyone
I think what you're after is a special effects paint, reffered to as 'crackle paint' or 'cracking paint' or variations thereof
before
after
Here's an example:
http://www.haymespaint.com.au/haymes/main.php?c=158
Directions For Use
The area to be painted must be clean and in sound condition. Best results are achieved over low sheen paint finishes. Semi gloss and gloss finishes must be sanded to a dull finish.
Prime bare metal and timber areas with the appropriate primer.
Apply 1 coat Haymes Low Sheen Acrylic. The colour selected will be the primary colour you will see through the Crackle Medium (cracks).
Apply Designer Finishes Crackle Medium with a brush or roller so that a uniform coat is obtained. Allow 2 hours to dry.
Apply 1 coat Haymes Low Sheen Acrylic paint by brush or roller. The colour should be different to the first colour used. Maxiumum effect is obtained by applying paint gently in a criss-cross pattern. Try not to paint over previously painted surfaces. Allow to dry over night.
Apply a coat of Haymes Simply Woodcare Aqualac Clear Gloss or Satin.
Do not apply if the ambient temperature is less than 10oC or greater than 30oC.
Coverage
Up to 10m2/L depending on surface pourosity and application method.
SIZES
Available in 250ml and 1 litre.
Most of the major paint brands have their own crackle paint. Problem is your colour choice will be pretty limited, and you'd want to check how durable the paint would be in terms of being used externally. Also bear in mind the application method will affect the size and pattern of the cracks, so given how big a car is, it might be hard to get a consistent effect, if thats what you're aiming for
VWFREAK ·
Turns out it was an April fools joke which has back fired on Volks World. Dirty Fu$%ers.
byronbus ·
haha, publishing it in may could have confused people
