Aussieveedubbers 路 Tech Talk
can anyone tell me (while my hands are dirty hehehe)
https://forums.aussieveedubbers.com/threads/7022/can-anyone-tell-me-while-my-hands-are-dirty-hehehe
Starbug 路
anyone know how many shims are supposed to sit on the fan in a beetle? i know there is probably a small difference between individual cars but how many on the underside and how many under the nut/washer?
not too sure how these should go as the last fan f'ed up because of not enough shims!
any help would be greeeeeeat!馃榾馃榾
Starbug 路
actually... not too big a need to know now, as the new fan is too big for the fan housing ive got! annoyance!馃槧 so now ive got 2 questions 馃檪
1) is a superbug fan housing bigger than than non-superbug fan housing and therefore can my bigger fan fit in it without scratching etc (the fan is not bigger by diameter, just bigger by depth)
2) how many shims inside and out blah blah blah!馃槈馃槈
any help would be much appreciated!
馃榾馃榾
[Edited on 1-6-2003 by Starbuggy]
jenz58 路
Wish I could. From the manuals I study it depends on the tension of the belt as to whether you add or remove shims.
I can't even get the nut off to remove the belt and pulleys to put a generator on I've cleaned up馃檨
I do the scew driver in the slot bit and all, but can't budge it:jesus
Quickbug 路
Jenz is right - just fit them on until the belt is the right tension, tight but so you can move it a little when grasping both sides of the belt in between your thumb on one side and your fingers on the other (if that makes sense!?)
Its a bit of a trial and error. I have to change my pulley shortley!
Jenz - tried a liberal dose of WD40??
:bounce
jenz58 路
Oops, forgot about that stuff, I have a can:thumb
Too dark and wet out there now馃檨
70AutoStik 路
Yes, the doghouse fan will not fit in the early style fanhousings. The shims are used to set the fan-to-housing clearance. Put as many as it takes on the generator side of the fan to prevent rubbing.
Quickbug 路
Well i changed mine today since it blew up on the way to work.
I put 4 or 5 in the middle, between the two peices of the pulleys.
70AutoStik 路
It blew up! How high you revving your engine? 馃榾
BTW, It's a public Holiday here in West OZ, Foundation Day, you should live here - wouldn't have the problem. 馃榾
Quickbug 路
Yeah well i got all week off now!
SO NER!!
Oh but i am sick so that kinda ruins it... 馃檨
How high?
Dunno - i havent put my tacho back in.
About 5-5.5k prolly. Maybe more.
Its the second pulley that has exploded on me... but they last about 6 months or so. They seem to be a big weak point...
edit--> its been dying for a bit - rattling and so on. Thought it might have held in for the rest of the week tho... rude bastard of a pulley... 馃槧
I have been taking it easy - the one time i ask for some acceleration and it gives up the ghost...
[Edited on 2-6-2003 by Quickbug]
Starbug 路
Thanks ppls馃檪 figured out the right amount... but had to buy a smaller fan 2nd hand for now... holidays soon so im going the upgrade (to the shinier chrom-ier doghouse and friends....)
the last fan i had on there got eaten through by the washer... not happy jan!:cussing
jenz58 路
My belt was too tight and was the probable cause of the bearings going in the generator as it was fine until I'd been driving then it started making terrible noises after a while. There were way too few shims and no give in the belt:jesus
Also learnt that shims are used to give required clearance for the fan so it doesn't hit or scrape anything as mentioned here.
Hmmm, it's all a learning but the hard way:o
Generator I've cleaned up is not charging but at least no horrible noises so bearings OK. Pity it doesn't work, have it looking so sweet externally
Damn can't win
Can you buy new 6 volt gennies and regulators?
Quickbug 路
I think you can only get reco'd now Jenz.
Try giving Bosch a call though, as i got a new 12v generator only a couple years ago...
amazer 路
before you go buying a new genny jenny hahahahahahaha haaaaa huh uh oh. OK. before you get another generator make sure its not something simple like worn brushes.
jenz58 路
Grey 57 is checking it out for me. Oops no he is putting bearings from a 6volt he has into the one we took out which was at least charging, but suggested I find out if new ones are available. Still have the non-charging one on her.
He tried polarizing the gennie as well with no luck
Hmmm, the trials and tribulations of keeping Bel 6volt, 36hp
Looked online and all the results of my search were on 6volt-12volt conversions, so encouraging 馃檨
*jen ponders her gennie problems*hehehehe馃榾
Grey 57 路
Jen the fan end bearing was completely fried. Changed it over for a good one so it should be good to go.
One thing for anyone, this 6V gennie has 3 wires coming out of it not the usual 2. I know that the heavy one from the brush holder goes on one terminal on the regulator and one goes on the other terminal. But what about the 3rd wire??
Any clues.
