Hoodjax sales/installation at Nambucca Spectacular
https://forums.aussieveedubbers.com/threads/70315/hoodjax-salesinstallation-at-nambucca-spectacular
Hi all, I will be selling Hoodjax at Valla and installing for free! $80. Let me know if you are interested and I'll make sure I bring enough... I will be camping
wiseoldub ·
as per convo with you the other day! my hand is up for a set! put in a pic with a before and after shot and the cooling properties and i bet you will sell a few more!
cheers josh
0414 726194
Like this, Josh?!
Hoodjax is a decklid stand-off device for Beetles (all years) that allows the top of the engine lid to be propped open, letting in plenty of fresh cool air for maximum engine cooling and performance. Thanks to the use of quick-release R-clips, Hoodjax is quickly and easily removed for security and for driving/parking in cold or rainy weather, or for ‘stock’ appearance. Ideal for rats or sleepers! Hoodjax is especially good for pre-1971 with no factory engine lid vents.
Hoodjax has been proven over more than 15 years to assist the cooling of big bore, stroker and turbo engined Beetles. Hoodjax helps deliver maximum power and reduces the 'hot idle' stumbles caused by fuel vaporisation - especially in summer.
Installation is DIY and takes around 15 minutes for initial fitting – after that, Hoodjax can be removed in seconds in your driveway or by the roadside. Installation requires two 10mm holes to be drilled in your engine lid’s hinge C-brackets, plus the use of some other simple hand tools. Instructions are provided. A secondary benefit is that your engine lid is now quickly removable for easy engine bay access during servicing.
wiseoldub ·
that is perfect dude!!!
i'll be happy with my set fitted for all those reasons!!
you reading this chris?
Matt Ryan ·
Put me down for a set.
I will be camping too, in amongst the DSK crowd, will be there Thurs arvo 'till Mon morning.(depending on size of hangover)
Regards,
Matt.
phatratpat ·
got them, there good ,they work !!👍
thanks for the thumbs-up!
bumpsies 😎
GTMac ·
I will take a set for my Fasty 🤪
GTMac wrote:I will take a set for my Fasty 🤪
lol... okay, I'll bring my 100mm holesaw 😂
