Crazy Fuel for Dynoday [Bris]
https://forums.aussieveedubbers.com/threads/70324/crazy-fuel-for-dynoday-bris
matberry 路
I was wondering if anybody is interested in sharing some special mix fuel for the dyno run on the 19th.
20l cost about $100 and needs to be ordered by this friday. It is a racing blend of 105 RON with some pretty complex formulation that is meant to aid in its oxygen carrying capacity....= more hp!
Matt
Craig Torrens 路
why not just run on pump 98 octane ?.......................I doubt that "special" fuel would create more HP unless you have a compression ratio to suit.....but I could be wrong.
I think its better to see what your motor is capable of achieving without the special stuff, just 100% street available fuel..............but each to their own I guess 馃憤
If you do use the special fuel, would be good to see some comparisons of HP between it and pump fuel. I guess you would have to drain the tank and refill.
$5 per litre.......about what we will be paying next year for fuel 馃槀
GTMac 路
God dammit, I think I have to agree with Torrens for once! Real world is that you will fill up with 98 or best 100 at Shell.
Have heard of cars going backwards when tuned at 98 and then putting in the 100 or higher.
matberry 路
Fair points guys, I certainly realise that dyno runs using 98 first would be the go, on a comparison basis, but incase you didnt realise, this is technically a competition, so maybe people want to aim for MAX HP. The guy that blends the stuff recommends with 2-3deg extra timing you will make more power. That being said, I was only offering what has already been offered to me.
Shell offering 100 octane? Which pump is that, 98?
ang3lsholocaust 路
Shell offer the V-Power racing which is 100oct
at a few selected sites.
It is a ethonol blend but only 5%.
some people ovoid using ethonol products, but i would say try it, Its only a 5% blend, not 10% like everyone elses.
Ethonol burns hotter, giving you an increase in performance.
Well thats the general feedback i am getting from it.
We use it in our cars
You can pic some up at kessels road Mt gravatt or compton road Runcorn on the south side heading to the dyno day.
colin 路
May i suggest that people having their car dynoed should use the fuel in which the car is tuned too.
If you start running different fuels you must remember that they all have slightly different viscositys.
Therefore you may go backwards as your cars jet requirements may be slighty out.
Anyways i agree with Craig, real world numbers please.
Cheers Col
BeetleJuice 路
Craig Torrens wrote:why not just run on pump 98 octane ?.......................I doubt that "special" fuel would create more HP unless you have a compression ratio to suit.....but I could be wrong.
I concur!
JVLRacing 路
GTMac wrote:God dammit, I think I have to agree with Torrens for once! Real world is that you will fill up with 98 or best 100 at Shell.
x2馃槀
bond 路
GO 4 IT MAT!!!!
and ethanol burns cooler than gasoline. hence why pure alcohol is used in race/drag engines.
nick
Brad 路
you jet your cars ? doesn't the little man in the box with the wires do that ?
GTMac 路
Buggy Brad wrote:you jet your cars ? doesn't the little man in the box with the wires do that ?
Some of us have moved into the next century馃槀
matberry 路
Well you guys dont like it hey?
The sg of this stuff is meant to be .776, which is close to unleaded, so I'm told. [yet to find sg of the bowser fuel]
Aparently if the sg is the same, your old fasion carbs deliver the same amount of fuel, its the octane [amount of oxygen] that makes the performance increase.
When I set up my efi drag engine in 94, I did some comparison tests between av gas and super and the actual fuel maps hardly changed.
I realise we dont want to have lean conditions occur, but I doubt if every engine is tuned that close to perfect, that it would make it, or break it !!!
Craig Torrens 路
Buggy Brad wrote:doesn't the little man in the box with the wires do that ?
or women.............don't be sexist 馃槀
Brad 路
no way is it a chick...
every day that little man in the geko box is up at 6 and ready to work, goes hard all day and then sits in the shed all night waiting for 6 the next day to do it all over again.. No way in hell is any woman going to do that ....
Craig Torrens 路
the women was up at 5 to make the little mans breakfast 馃憤
matberry 路
Craig Torrens wrote:the women was up at 5 to make the little mans breakfast 馃憤
馃槀
MickH 路
You mean she WAS breakfast.....馃檪
Craig Torrens 路
or dessert the night before 馃槀
Brad 路
Man trust me when I say my little woman aint getting up at 5 to make breaky, hell she wouldn;t get up at all if Stu didn;t start screaming after I leave for work ...
ang3lsholocaust 路
bond wrote:GO 4 IT MAT!!!!
nick
馃憤 cheers
matberry 路
Well I have to order this today, but I wanted maybe 2 other cars to share it with.
I'll check at lunch time.
Craig Torrens 路
Just buy it for yourself..................run what's left over in a street car !! 馃憤
BiX 路
If you only want a few litres, i can probably get you some pretty easy. Its one of the jap blends, 105 octane. nasty smell though......
The last driver i nav'd for buys it 200L at a time for his Evo6RS. Does 2km/L at full noise, its scary what he spends on fuel at an event!!
matberry 路
Bix , thanks for the offer. The fuel I mentioned is blended locally I believe. Your mate must have some fun to make it all worthwhile.
Craig Torrens 路
BiX wrote:The last driver i nav'd for buys it 200L at a time for his Evo6RS. Does 2km/L at full noise, its scary what he spends on fuel at an event!!
Wow that's some $$$$ on fuel.................................bit like Heath's tyre budget in hillclimbs馃槀
2tone 路
Any NEwz on the WV Valla Festival at Nambucca Heads 2008?....
tm.:
ang3lsholocaust 路
2tone wrote:Any NEwz on the WV Valla Festival at Nambucca Heads 2008?....
tm.:
check this site out
http://www.volkswagenspectacular.com/
