What to do floor seal today - Which way does it go.
https://forums.aussieveedubbers.com/threads/70374/what-to-do-floor-seal-today-which-way-does-it-go
Camo ·
Just went to start putting the seal on and noticed that the seal has two different size edges. One is about 9mm diameter and the other is 7-8mm diameter. Which one goes towards the outer edge.
Photo not clear, but you will understand. The bigger is on the right in this photo.
Thanks, Kevin
Newt ·
Kevin,
Is that a standard pan/body seal, or out of the nose of a KG (or are they basically the same?).
Newt
That is a copy and not even the same as the og seal. Put it however you wish.
Gibbo ·
Can I suggest big side facing outwards.. the more you have stopping stuff coming in the better, please correct me if Im on the wrong track guys. 🙂
Camo ·
Its suppose to be a West Coast Metric seal, got it from George at Classic. Is it possible that the Karman seals are different profile to a bettle and I have the wrong one.
Gibbo, makes sense the larger towards the outside 👍
Kevin
You should ring the shop u bought it from and ask how its fitted
