liam66 ·
Do swing axle rear drum bakes fit onto an IRS car?
https://forums.aussieveedubbers.com/threads/70440/swing-axle-to-irs-brakes
liam66 ·
Brad ·
mm well reading your add I see you have a 1970 Swing Axle rear end so in short yes they will as long as your swinger has long axles. If you have short you will just need to add a spacer after the drum and before the nut, although if you are going EJ I would goto Type 3 Drums or discs.liam66 wrote:Do swing axle rear drum bakes fit onto an IRS car?
liam66 ·
Brad ·
Nope not if your goiung IRS ...liam66 wrote:Cool, So there's nothing worth keeping off the swing axle rear?
