WTB Engine for a '67 Bug
https://forums.aussieveedubbers.com/threads/70466/wtb-engine-for-a-67-bug
JCARRION ·
Hi there.
Id need to buy a engine to fit into my 67 beetle.
Either new , recconditioned , second hand , etc.. in/around Sydney Area.
Francisco_javier_Carrion@yahoo.com
Thanks a lot !
robnjo ·
shame you are not closer...this will be for sale when I pull it out
pod ·
try this one
http://forums.aussieveedubbers.com/viewtopic.php?tid=70266
JCARRION ·
Thanks , Pod . That engine in the link is already sold 🙁
and I got my baby in the workshop , with the engine out , and paying a daily fee util I find an engine.
any ideas about how much should I pay for a full rebuild ?
my current engine still run ok , but Its got a lot (1/4 Inch !) of end-play . The front main bearing is actually spinning with the crankshaft and leaking oil like crazy ..
robnjo ·
for a good job you start from about 2400 upwards...
Menangler ·
I have a rebuilt twin port engine for sale, just up to tappet covers, no tinware, it has a machine in 88mm bore kit so displaces 1679cc, all new bearings, reco heads with new valves, it is on a type 3 case, but can be made to fit a Beetle. price is $950. engine is in Nowra.
Dave
JCARRION ·
Thanks .
Any can recomend me a well known reputable engine rebuilder around Sydney ?
J
JCARRION ·
Hi Dave . How easy would be for my local mechannic to fit it into a Beetle ? Is it complicated/expensive ?
Thanks !
Menangler wrote:I have a rebuilt twin port engine for sale, just up to tappet covers, no tinware, it has a machine in 88mm bore kit so displaces 1679cc, all new bearings, reco heads with new valves, it is on a type 3 case, but can be made to fit a Beetle. price is $950. engine is in Nowra.
Dave
barls ·
try contacting richard at vforce mate about a rebuild
Menangler ·
JCARRION wrote:Hi Dave . How easy would be for my local mechannic to fit it into a Beetle ? Is it complicated/expensive ?
Thanks !
If you have a twin port engine in your car now it would not be hard at all, I can supply a bolt on dip stick tube, he would need to drill and tap a pressure switch hole (has to be done very carefully as not to get any swarf in the oil gallery), or you can run a type 3 oil cooler with a pressure switch.
JCARRION ·
Cool Dave! .
let me see tomorrow in the workshop if my engine is single or TP .
Javier
