I have an exhaust system for a baja. I will swap for one to suit a standard beetle or make an offer if you want to buy it.
remote oil cooler , filter and adapter $50.00
I also have a 1600 SP. It was removed from a baja (running) and swapped for a TP. It has generator stand, clutch?, flywheel, front pulley, tinware,fanshroud, carby, manifold . I will have to have a look and see what other parts are there. It doesn't have generator, fuel pump, distributor as these were used by the previous owner for the transplant of the other motor .
One of the heads had a helicoil which has come out. I don't know if the head is still useable or not. $100.00
more stuff
1200 tinware $??
side panels cut out of a 70 model, rear cut
Also have guards and other bits from 70 model
cram ·
pm sent re exhaust
JCARRION ·
PM re: The 1600 SP
stevosky ·
no pm Jcarrion. try email button
stevosky ·
There is other stuff. If you are chasing anything send a pm
Anthiron ·
what carby is on the engine? would you seperate?
stevosky ·
Yes I will sell it. It is a Solex 30 pict 3. It came off a running motor but I can't guarantee it. I have moved the mixture screws when I cleaned it so you would have to set it up to suit your motor. It does have a stripped thread though on the front of the top cover. You might have to use a nut with a longer screw?
A pre 68 fuel tank $40.00
stevosky ·
Exhaust is now gone, thanks Cram
Camo ·
Cant believe people aren't jumping at this. If only it were in Sydney. I would say good luck, but I think I should be saying sucked in to the people who miss out.
Cheers, Kevin
Anthiron ·
thanks but i will leave it if it has a stripped thread.
