Hey guys, just filled up my tank and when I restarted the engine gave a small pop and now has a wheeze. I managed to drive home with little power. Any ideas what I could be looking for. I intend to check under the valve covers and see what I find. Hopefully nothing too expensive. Engine has been running fine.
Neil
Notch Nut ·
If it is making a "chuff" sound, it could have spat out a sparkplug. Check if any of the leads have plugs attached that aren't in the engine head. Happened to me once and a helicoil fixed the problem.
njg02 ·
Thanks Notch. All plugs ok but equalizer pipe was off on rhs. Car started and idled ok. I'm releived. What would cause that?
Notch Nut ·
Some things can come loose with age. If you do home services, best to check anything that is bolted on for wear etc.👍
