Extractors for ej20t ?
https://forums.aussieveedubbers.com/threads/70585/extractors-for-ej20t
liam66 ·
Can anyone recomend a set of matched length extractors for a wrx motor?
There's plenty of stainless ones on ebay- but they look like they'd hang pretty low...so all that nice polished, tig welded stainless won't look great with rock rash.
I dont want to be modifying an expensive set if they could be scratch built better....
X-I-TED ·
have you looked at outfront motorsports
liam66 ·
Strange you should mention that, just ordered their exhaust. Moves the turbo to the belt end (front , or rear in my case) of the motor. Grapped the reversed water jacket and polished inlet at the same time.
Not stainless, but is jet hot coated.
reub ·
http://www.outfrontmotorsports.com/exhaust_setups.htm#External%20waste%20gate%20exhaust
look cool...
ratbug ·
I ended up making mine myself. All stainless... shorter than the shortened sump. Not equal length, I want the EJ20 growl!
liam66 ·
I went with outfront as they moved the turbo to the belt side of the motor (hanging out in the breeze). probably not the best desicion but it'll look cool.
reub ·
Question whilst on the subject of extractors as I'm looking into them... What is the difference between pre 02 and post 02 EJ20's? They all appear the same??
From what I've read some of the quickest rexies still use stock headers, all of the after market ones Ive seen appear to be very low.
I'm going to give mine a a bit of port job, there seems to be a step where it meets the heads.
