replacing rear torsion housing caps
https://forums.aussieveedubbers.com/threads/70592/replacing-rear-torsion-housing-caps
type82e ·
I adjusted my rear suspension on my superbeetle
and I cant get the rear caps back on is there a trick to it
marcel
dangerous ·
I like to use some longer studs to locate the cap
and then snug the cap down progressively using nuts and washers.
Then replace the stud/nut with the correct bolts.
vwsteve ·
do it slow so you dont cross thread it👍
shaihulud ·
Sometimes I've fitted the caps very loosely and with the bolts just started in their holes, before I lifted the swing arms up into position. Sometimes it's the only way to do it.
Otherwise use longer bolts and do them up a turn each at a time in a cross over pattern, like doing up a head.
