my new donk馃槑
how could i pass this up $ for $ and $ for hp
New 2332 Turn Key Engine Price: $5500 obo
84 X 94 Universal Super Case, Welded #3 Cylinder
84mm Forged Chromoly Crankshaft
5.500 Forged Chromoly H-Beam Rods
Forged Chromoly Light Weight Flywheel
Manton Chromoly Push Rods. .035 wall thickness
94mm Mahle Piston/Cylinder Kit
#2246 Camshaft 308掳 duration x 410 lift at cam
1.1 Ratio Rocker Arms w/ swivel feet adjusters
Hardened Rocker Shafts
Billet Distributor Clamp
044 Heads 42 x 37.5 Stainless Steel Valves,
Dual Springs, Chromoly Retainers
Stage 1 Kennedy Pressure Plate w/200mm Daycon Disc
Bosch 009 Distributor w/Bosch Blue Coil
Dual 44 IDF Weber Carb Kit with CB Hexbar Linkage
Doghouse Fan Shroud w/ high amp Bosch Alternator
26mm Keyed Oil Pump
Degreed Crank Pulley
Chromoly 8mm Head Studs
94mm Teflon wrist pin buttons
Windage Tubes
Chromoly Straight Cut Cam Gear Assembly
8.5:1 Compression, and dyno tested 195 hp on pump gas
Complete Offroad exhaust
http://www.thesamba.com/vw/classifieds/detail.php?id=613930
X-I-TED 路
