Drop spindles - will these fit a 71 type 3 bj?
https://forums.aussieveedubbers.com/threads/70611/drop-spindles-will-these-fit-a-71-type-3-bj
sinecure ·
http://cgi.ebay.com.au/VW-VOLKSWAGEN-BEETLE-DROP-STUB-AXLES-EMPI-RAT-ROD-LOOK_W0QQitemZ130238732210QQihZ003QQcategoryZ6763QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If they don't fit, why? Can they be modified to fit easily?
mackaymanx ·
No and no they can't be modified to fit. The only dropped spindles I have seen for the type 3 are these. http://www.thesamba.com/vw/forum/viewtopic.php?t=244520
sinecure ·
Thanks, may have to check if those will be legal over here. A$780 is a bit steep though.
mackaymanx ·
The only other option I have seen is mounting a type 1 beam up to the type 3 frame head (usually done to run narrowed beams). Only way to get those drop spindles legal would be to buy 2 set, let your engineer test 1 set to destruction and use the other set.
sinecure ·
I take it that swapping beams isn't as easy as it sounds.
mackaymanx ·
http://www.thesamba.com/vw/forum/viewtopic.php?t=305529&postdays=0&postorder=asc&highlight=type++beam&start=20
http://www.thesamba.com/vw/forum/viewtopic.php?t=301887&highlight=type++beam
sinecure ·
Thanks for all the info. Found another story with some good pics:
http://www.kustomcoachwerks.com/forums/viewtopic.php?t=2627
I'm not sure chopping the bottom off the front frame horn is something I would undertake as a novice. I guess I'll just keep wrecking bump stops!
