Aussieveedubbers 路 Tech Talk
Clutch Cable
https://forums.aussieveedubbers.com/threads/70749/clutch-cable
UberMod 路
So after months of waiting for my green machine to make it to these Sydney shores, after a whole three days of driving I can't select any gears 馃ゲ.
I think it's a clutch cable problem, is it common for the cable to stretch? Depressing the clutch pedal operates the clutch lever but not enough to disengage the clutch so that I can select a gear when the engine is running, (selector is fine with the engine off). It looks like there's no adjustment left so am I right in thinking it's stretched and it's time for a new one?
vw54 路
time for a new cabel and also the outer as well
also check the universal joint under the back seat and cover plate it joins the gear stick rod to the gearbox this may be loose or need replacing
are the 2 bolts that hold the gearstick in place tight these may also be loose
a few things to check
subisupa 路
I had the same drama in my baja, the outer steel tube had come off the pan inside the tunnel.
68AutoBug 路
the cable is known to stretch before breaking
so its best to pull the old one out while its still in one piece
greedy53 路
it may need adjusting check the wingnut on the cabel on the gearbox
68AutoBug 路
He said there was NO adjustment on the cable
He could always put a large nut or a few big flat washers on the cable under the wing nut..
but the cable is on the way out
and this may keep You going a little bit longer...
the cables stretch and break strand by strand..
Joel 路
just replace it now while its still in once piece b4 a bandaid fix leaves u Uber stranded
UberMod 路
Joel wrote:just replace it now while its still in once piece b4 a bandaid fix leaves u Uber stranded
My sentiments exxacly, it's got to be easier to replace this way.
Next Question, where is the best place to get a new one from? I'm new to the Aussie VW scene so haven't got a repertoire of suppliers etc yet and I'd like to know who provides quality parts, internet searches provide frustrating results.
Many thanks for your comments 馃憤
Uber
vw54 路
closest to you would be
Vintage Vee Dub 9789-1777 or Unit 1 11B Harp St Campsie
plus you get a forum discount
UberMod 路
vw54 wrote:closest to you would be
Bookmarked that bad boy, thank you kindly
馃檪
