corrosion in fuel tank
https://forums.aussieveedubbers.com/threads/70775/corrosion-in-fuel-tank
oldnslo ·
while doing the resto on my 56 beetle had the fuel tank sitting around.Even though it was sealed, After painting it and removing the coke bottle bottom i had duct taped around filler neck I noticed bits of surface rust forming around inside. Anyone know of what i can do about this?
apply rust converter n se if you get any holes then it will require a bigger repair
oldnslo ·
no holes definetly thin layer of surface rust
ancientbugger ·
I've seen in a UK magazine 'Practical Classics' they use stuff called a slosh coat for the insides of fuel tanks (obviously you pour it in and slosh it about😎). If anyone on this site knows of this stuff or a brand name it would be very handy
You could also fill up the tank with some nuts n bolts and a little kero or petrol
then slosh shake it around to remove the surface wash n flush out to remove any rust particles
Mick058 ·
vw54 wrote:You could also fill up the tank with some nuts n bolts and a little kero or petrol
i did this with my tank. Worked quite well. You can also just use some chain. Anything that will scrap off the surface rust flakey bits.
