Rocker geometry HELP!
https://forums.aussieveedubbers.com/threads/70846/rocker-geometry-help
VWFREAK ·
I' after some assistance from a geometry guru to assist me with the correct push rod length for my combo.
Engle 110 cam, with Empi 1.25:1 Rockers, Scat 69mm crank
When it comes to technical mathematical equations, I'm not your man.
Thanks in advance
Peter / Bones
mactaylor ·
make an adjustable pushrod like damien pells dangerous should jump in here too
VWFREAK ·
I figured as much. I'm trying to take the guess work out of it and have an exact measurement for guidance. If in doubt ? Ask some one who knows.
Not very forgiving if you get it wrong.
Anyone else.
xornge666x ·
If you wear glasses, you are sure going to need em to read this, but decent info here
http://www.cbperformance.com/Oct2005.asp
hellbugged ·
there is no set length........
it will all depend on YOUR engines width, finished valve stem height head castings height etc etc etc
search my engine build out, it may have pictures but i'm sure there is decent description
and also look through here..........
http://www.shoptalkforums.com/viewtopic.php?t=107350
VWFREAK ·
Thanks for the info guys.
