johannes ·
I have a 2L VW air cooled engine with additional oil cooler and oil temperature and oil pressure gauges [VDO]. Lately when turning on the ignition/engine, the pressure indicator moves right across to the right max. and sticks there until the igntion is turned off. It used to sit near maximum when cold, when warm it would indicate lower pressure at lower revs. The oil temperature gauge [VDO] used to sit steady at whatever temperature [from cold to 90C]. It now only indicates a temperature if reving above 2,500. below that the indicator needle is very unsteady and even drops below minimum. Am I likely to have an instrumentation, pressure regulator/line, or even an oil pump problem?
