Low revs Stalling Issue
https://forums.aussieveedubbers.com/threads/70874/low-revs-stalling-issue
Brissybug ·
My Beetle will stall during the first 5km's of driving when it gets to the low revs when in gear, its fine when bought to idle, it runs well, and I can counteract this stalling by reving it when moving.
What is the problem... it goes when the engine is warmed through...... and how can i fix it?
trickysimon ·
What engine? What Carby? What Distributor? Heat Risers Intact?
Simon
Brissybug ·
Engine: 1200
Carby: original from when i bought it 3 yrs ago... don't know history
Distributor: recon'd last year by autoelectrician
Heat exchangers are brand new.
greedy53 ·
all fuel filters new the one in the tank
Brissybug ·
Yep... all the fuel filters were replaced last year, and she's only driven a few 1000km.......
Brissybug ·
She's been stalling since we put the engine back into her, she had a cosmetic engine upgrade, so all the easy parts have been replaced... spark leads, fanhousing etc.....
Can anyone work it out???
pod ·
air leak??,make sure all is tight ,manifold to heads and carb to manifold
Brissybug ·
Thanks, we'll have a check tonight
mnsKmobi ·
I'm not familiar with Beetle motors but I believe that they have 4 warmup mechanisms: exhaust heat riser (mentioned above), hot air intake into carb, thermostatically controlled flaps to reduce cooling air when engine is cold and the choke in the carb. Are all of these present and working?
You could also have a look around this site:
http://www.vw-resource.com/
