This is on a 1600 912 engine with dual Solex PII 40. The car came with an electric fuel pump replacing the orginal mechnical pump. Although the electric pump helps the engine starts quicker, I m worried that the pressure within the lines will evenually burst a hose somewhere and a nice little fireworks show will be the result. I purchased a regulator which I will install but what is a typical pressure setting should I have for such engine? I know its not VW but the concept should be the same as any 1600 VW engine with dual carbies
it wont burst the lines.
Sides ·
To burst the lines you'd have to have some crazy high pressure - you'd get the fuel pressure overpowering the float valves in the carbs and making them run rich a LONG time before that.
Webers and Dellorto's are happiest around 3 to 3.5 PSI, and I'd assume your Solex's would be happy round there too. That's what I used to run the Kadron's on my old 1640 and never had a problem.
the pressure shouldn't be enough to burst fuel lines
a loose clamp and fuel leaking maybe...
but as someone said, the needle and seat in the carburetors would leak before any damage to fuel lines.
I run around 3 PSI on My electric pump...
I have a small gauge on the regulator..
PS: good idea to have a switch to turn the pump off...
I was caught with mine off 3 times at Valla... lol..
I switch it off when parked.. so it only goes about 100 meters... lol
