My 1835 doesnt appear to be firing on 1 & 3 the compression is good I did a cylinder leak down test and that is all good the valves are all adjusted correctly the plugs are new the leads are good I am starting to run out of ideas and the ones that are left are not very appealing if anyone has 2 cents to through in feel free
greedy53 ·
the opposite numbers on the timing fireing order hoe is the dizzy cap when did it start after you done something anything like that
could be a bent dizzy sharft too
When isnt it firing??
Idle??
What carbs??
How is it at full throttle??
running kardrons by chance?
or similar small single barrel twin carbs
they often have a tendency to do this but only at idle
silver ·
where are you?
hewpt ·
it seems to be at idle the old girl still gets up and goes, I have a 40 dcnf on and the cap is in good nic I am not so sure about the dist shaft would it be easy to see that is bent or should I pull it out and get it checked,i am in Perth
it aint bent if it runs how do u know it aint running on 1 and 3 ????
do u have the plug leads around the right way 1 4 3 2 check this first
hewpt ·
the leads are ok and in the right order if they were out the missing and backfiring would only get worse ?
greedy53 ·
try swaping the plugs around see if they cause other cylinders to fail worth a try
hewpt ·
Tried that and put new plugs in as well
many single-barrel twin carbs (Kadrons etc) exhibit this behaviour at idle
hewpt ·
Im running a 40 dcnf do they have that problem at idle if so is there any fix for it
