long story...I've got a 8mm headstud thats been welded together to lengthen it and it's snapped right at the weld. I need it to be longer cause the stupid bastard who pulled the thread out of the case didn't do the correct thing and put a helicoil in to fix it. All they did was tap further into the case and then lengthen the head stud to suit. Wahey! not. So now I need to make a longer headstud, what are they made out of? I'm fairly certain that they're not mild steel and if they're hardened I think I can make one from a screwdriver we've got here. Anyway I need to know what they're made of ASAP. Thanks.馃槑
Joel 路
ive just replaced mine with Scat chromemoly ones
they are obvoiusly made for stroker engines cos i had to cut them down for my 1776
heres what happens when there only made out of mild steel....
high tensile only way to do it properly
dangerous 路
Try 4340, or 4140 material.
Or EN26 if they have it in that small diameter.
You can have it heat treated after machining, but for a basically mild engine
you can buy the material in a 'hardened and tempered' state,
and that should do.
dangerous 路
In a perfect world the threads should be rolled to help prevent a failure,
but short of buying a whole set of aftermarket long studs(to only use one),
'turning' the thread should get you out of trouble.
1303Steve 路
Hi Boozer
My memory is getting dim so I cant remember which stud, but the one deeper head stud was standard from the factory with 8mm head studs, where as the 10mm ones were all surface mounted.
vw54 路
Boozer tell me the overall length and i will have a scrounge through the stock and see what i have
its 8mm right ??? and the length is
Boozer 路
don't worry guys I've changed plans again. They've defintely tapped further into the case and done a shit job of it. We didn't feel good trying to make a new headstud and hoping that it was gonna hold in the case. So I'm gonna put the kombi motor in and replace the case. But thanks anyways!
