wtb: Engine generator and cooling shroud
https://forums.aussieveedubbers.com/threads/71432/wtb-engine-generator-and-cooling-shroud
BLUE_62 ·
Currently have a 1966 1300 with a very noisey generator bearing or fan bearing. Has anyone got a good second
hand one they'd like to sell?
greedy53 ·
what is it 6 volt or 12 volt
BLUE_62 ·
Its a 12v system. Had a closer look, its almost like the cooling fan has free play on the shaft. If you spin it one way and lock the pulley with your hand you hear it jar..
greedy53 ·
sounds like the key is warn pull it apart and have a gander cheeper than buying another one or it may have cracked the fan even the nut may be loose
the best thing is to remove the genny and look
bushed ·
check side screws on fan housing aint loose
if u yank the housing or push it while spinning the genny you may find it touches the fan////this may be ur prob/ also
BLUE_62 ·
ta guys. will remove and have a look at the weekend.
Its been a while since ive had a beetle so kind of re-educating myself on things again. lol :P
bushed ·
remove eng lid 10mm socket watch the kamakasi spring
remove 13 mm nut and bolt on genny clamp
remove shroud 10mm bolt or (cheesehead screw) left and right bottom of shroud.
slide shroud up and out when any wires are disattached from clips on shrousd and coil etc
esevwbits ·
have black cooling shroud if u still need. PM me for details.
