grogy ·
anyone put one in a rhd bug, lhd fittings connect to side closest to tunnel , not much room. if u turn it upside down the connections to the resivoir are underside, under pressure to leak. can the lines which go to the back of the car be fitted to the front of the cylinder [close to front of car] and the 2 front brake lines be moved to the rear position. can the electrical fitting be moved to any spot. appreciate your help...... grogy
