Aussieveedubbers · Watercooled VW's
Need help fitting 'go fast' chip
https://forums.aussieveedubbers.com/threads/71586/need-help-fitting-go-fast-chip
Volksaddict ·
Bought a chip for my T3 and cant work out how to plug it in..appreciate any help...Thanks
johny rotten ·
yep easy
johny rotten ·
remove metal cover you will see it in side, take note of the notch in the end of the chip it must go in the same way as the old one
where did u buy the chip and how much was it ??
barls ·
dont forget all your antistatic precautions as well. otherwise you might damage both chips
Volksaddict ·
..thanks for the info ..was tempted to take of the metal cover but thought id better ask first!!!...the chip came from Vintage Vee Dub (where are you Dave aka VW54) ..cant tell you how much as i bought it secondhand (unused )
be very gentle when pushing it into the housing as the pins are fragile
Volksaddict ·
...all installed ..easy when you no how..Thanks All
So the putor is fitted back in the Van and its running ???
Volksaddict ·
vw54 wrote:So the putor is fitted back in the Van and its running ???
Yep all good...might have a fuel regulator problem though as new Bosch pump is humming ..will get it tested .bloody VWs ..always something ..just finished fitting aircon ...what a job dash out etc ..also fitted stainless exhaust and dumped it 2 inches
sounds good Ray where did you get the chip from
you just need the ratio rockers now
kombi kountry ·
you'll have to post some pics.
i've got the chip, rockers and exhaust on my 89 T3 manual. i was impatient and got the exhaust done at a local muffler place without much asking around. it seems to have improved flow, but the sound isn't so good. he also had to put a resonator on it.
i was giving it it's first real run on Mt Ousley and was pulled over by the highway patrol car.....he let me off on a lesser charge....i think because he thought his speed camera must've been reading incorrectly as he seemed taken a back that a kombi was doing such a speed....up-hill.
Special Air Service ·
Volksaddict wrote:..also fitted stainless exhaust and dumped it 2 inches
Ray, where did you get the stainless exhaust from ?
And where did you get the lowered springs from ?
(assuming thats how you lowered it)
Brendan
