Aussieveedubbers · Bugs
4 stud hub conversion
https://forums.aussieveedubbers.com/threads/71687/4-stud-hub-conversion
baja burley ·
how do i convert the 4 stud hubs on my super to a 5 or a 6. is there a regular donor hub which is easy to wack on?????
buy some blanks from one of the suppliers and have them drilled for whatever pattern u want
fitting studs is also a good idea while ur at it
trickysimon ·
Yeh except they are illegal and dangerous at the best of times.
Simon
Rural Baja ·
baja burley wrote:how do i convert the 4 stud hubs on my super to a 5 or a 6. is there a regular donor hub which is easy to wack on?????
Buy an earlier beetle 😂
Guess it depends on if its guna be bush, road orr beach..... Wouldnt have adaptors on the road.... But maybe on the beach. The super would have discs on the front???? So the back drums i think you can swap for a wide 5 drum..... At least i thinks so....
MickH ·
jsheppard64 wrote:i drive around with adapter on the back everyday and none of my wheels ever come off... sure they may not sit exactly in line with the center but they're not that much off. and just in case i had a mild thread locker on them. and silicone the plate to the drum so it looks like one piece which would fool some cops...
Just don't have an accident as they aren't legal.
barls ·
also dont go bragging about those sort of things on here as we do have members that work for the various roads and traffic authorities on here
You might 'fool' some people - including yourself - but not the Coroner!
trickysimon ·
I didnt expect one of my wheels to fall off once, didn't stop it from happening. Lucky it was only at around 5km/h when it happened because I was about to go out onto the highway. Might not have been here typing this then.
Simon
jsheppard64 ·
I'll put the standard wheels straight back on.. the rear camber chewed most my tyres away anyway
baja burley ·
did volkswagen only make front discs in 4 stud???
and also what is the latest bug model that had wide 5 drums on back (im assuming the later model will be better performance)
will these bolt straight up to my super after stock ones are removed???
