tuff as nails.but. what is taking so long with this car,lack of funds or shit slow workmenship.it has been out for a while now..we would be keen as punch to help out if needed,we want to see this car back in action.
wastegate pipe is proberly to small i hope that you are putting on a bigger one.
and why are your shocks so imbound the angle looks aliitle wrong,but in saying that its hard to tell from limited photos.
keep the pic's comong and for god sake hurry up.
11CAB ·
Judging by these pics, it looks like its been to the track.....what times is it running?
LIFE IN THE LOW LANE ·
Obviously it isn't finished being repaired after going on it's lid??
Dak-A-Tak ·
What happen to Pics , gone are they . Did Trent delete them .That was great vw porn !
sorry
deleted both posts when trying to put pictures into same posts
some new photos , more on thursday if trent works on car
Yes Dave bigger tyre and time frame soon, as trent wants to get the car out , do some runs, then strip and paint.The last roll over was very costly.
Westi , the shocks are not mounted at the bottom, so wheel height could be set up on the jig to mount the guards
The wastegate is the correct size for a high boost motor. The car uses a co2 style boost controller designed by ron lummus, new to the car to control boost better than the motec.
some new pictures, let me know if you want the last ones up again, sorry again
Stanley ·
Looks fantastic. I like the grey will it still remain or have you a different colour in mind?
I also like the fact the volksy dash is still there in the background....👍
10x10x ·
some more
10x10x ·
Dash is to stay, colour ??? probably grey
vassy66T1 ·
Hot, hot, hot!!
A beetle looks great with a bunch of fat slick and scraping the ground 😎
CO2 boost control ... how does this work?? Sensor?
westi ·
i pulled this of the net for you to under stand staley.
it pretty basic once you have read it and it makes good sense.
10x10
i under stand the co2 set up.but after making a fair few manifolds in my time pipe size and placement are also just as important as the choice of size waste gate.and its flow.
i look forward to updates as the car will be nothing short of a masterpiece as always.
Co2 Boost Control: In order to understand why Co2 boost control is needed in some applications, basic knowledge of how a wastegate and boost controller works is needed.
An external wastegate has a diaphragm which creates a seal, and a spring which holds the wastegate closed. Spring rates vary depending on the amount of boost you want to run. Typically they are given in a "bar" value. For example, 1 bar would be 14.7psi. This would mean that in order to open the wastegate you would need to exert a greater pressure than the 14.7 psi spring holding the wastegate closed. In order for the wastegate to work you must have the boost reference port hooked up to the compressor side of the turbo or intake manifold. If you don't have this vacuum line attached then the boost pressure will not be limited to the set spring pressure; it will build unlimited boost pressure until your engine is destroyed (“bottom” wastegate port). Normally, exhaust manifold pressure pushes against the valve and diaphragm (through the vacuum line attached to the compressor reference port) which in turn pushes against the wastegate spring. When the exhaust manifold pressure exceeds the spring pressure the wastegate’s plunger opens releasing the excess pressure through the wastegate outlet (typically via a dumptube).
The top port on the wastegate is normally open to the atmosphere. This provides no additional resistance to the wastegate “spring”, and the wastegate will operate at the desired spring pressure. In order to increase the amount of boost over the spring pressure inside the wastegate, two methods can be used.
The first method is using a manual boost controller. A manual boost controller works using a spring and check ball. By screwing the adjusting screw into the boost controller you put more pressure on the spring which reduces the amount of airflow through the boost controller and into the boost controller port (“bottom” wastegate port). Less airflow means less pressure will be assisting the spring to keep the wastegate plunger shut. The “top” port is left open to the atmosphere with a manual boost controller.
The second method is using an “electronic” type boost controller. An electronic boost controller uses a solenoid inline of the boost pressure source to the top port on the wastegate. The solenoid is “pulsed” by a PWM (pulse width modulated) output from the boost controller or engine management system. With more opening and closing of the solenoid more pressure is applied to the wastegate. With less opening and closing, less manifold pressure is applied and less boost is achieved. When more boost pressure is applied to the top port of the wastegate, it directly applies more force to the wastegate valve, keeping the valve shut until enough exhaust pressure is applied to open the wastegate. This is essentially like adding a higher rated wastegate spring (stiffer). The bottom port of the wastegate is connected directly to the pressure source (compressor cover or intake manifold), with nothing installed inline.
Exhaust pressure increases as boost pressure increases. The amount of exhaust pressure in the exhaust manifold is affected by the turbo exhaust wheel size, exhaust housing size, exhaust manifold type (equal length or log), displacement, cam profiles, etc. In most situations using a manual boost controller you are not able to increase boost much more than a 2:1 ratio, meaning if you are running a 10psi wastegate spring you are not able to increase the boost much more than 20psi. With an equal length manifold, and large turbo sometimes a 3:1 ratio can be achieved. When using an electronic boost solenoid on the top port of the wastegate, as much as 6:1 ratio can be achieved if an equal length manifold and large turbo are used. For high boost applications, using a small wastegate spring for lower gear traction an electronic boost controller is what is necessary. For most turbo set-ups (probably 95% of what is on the market) achieving a 6:1 ratio is not possible. This is where running a compressed gas that can apply greater than manifold pressure is necessary. For example, a 3psi wastegate spring can be used, and flowing 90psi of co2 pressure to the top port of the wastegate will allow for greater than a 6:1 ratio. This gives the ability to get the boost low enough to aid in traction, and increase boost to pressures in excess of 50psi if needed. The boost solenoid vents the excess Co2 pressure so that target pressure can be reached. This also allows for more boost consistency with elevation change, as you are not relying on less available atmospheric pressure for the turbo compressor to work with. Boost controllers such as the AMS-1000 or AMS-500, and the AEM boost controller solenoid being used with the AEM EMS or Hondata systems are compatible with Co2. It should be noted that Co2 as a pressure source is not practical for a daily driver, and should really only be used for drag racing applications.
Turbo54 ·
Westi, great summary and totally understand. Thanks.
Off topic and should be in another post called ASK WESTI!
I am running internal wastegate GT2871R and am doing the exhaust and muffler at the moment. Thing is I have looked at so many different exhaust flanges and dont know whether to run a big exhaust or a splitter in between the wastegate and exhaust. I have heard this can cause pressure opening or kreeping the gate open with the exhaust gasses sucking the gate open. Is this true, what is the best setup? My whole exhaust system is only 1.5 feet long and using 2.5 inch pipe to keep the speed up.
Also on the subject of CO2, (Drag racing only) what is you setup your turbo completely seperate to the motor and spooled the exhaust turbine with CO2 and forget about the exhaust manifold and regulate it with soloniods? This would run cooler, get instant boost with no lag. Would this work?
T54
vassy66T1 ·
Very well explained!!
Turbos are a fascinating little invention with a myriad of tricks up their sleeve.
Sick68VW ·
This car was on a tow truck bout 2 months ago leaving city performance where was it going ??
10x10x ·
GD race cars owned by Glen Davies located in the CV Performance workshop.
10x10x ·
poor quality vw
reub ·
10x10x ·
Peter could you please give trent a call at his shop
"A fish called coogee" on 96647700
10x10x ·
sorry no more photos. No work on car this week.
Trent is trying to do 3 days next week. will post asap
10x10x ·
mounting rear panels etc
10x10x ·
more photos
10x10x ·
new inlet manifolds
intercoolers removed and machined down
10x10x ·
new rear body mounts
STOCK ·
ONE WORD AWSOME 👍👍👍
reub ·
SCHWING👍
STOCK ·
i think i have wood😂😂
10x10x ·
new throttle body and start of new aluminium exhaust. exhaust to exit through deck lid.
10x10x ·
machine second inlet manifold for new ones .
pete wood ·
awesome! 👍
10x10x ·
new inlet setup
10x10x ·
setting up exhaust through deck lid
10x10x ·
more exhaust, machining exhaust flange off turbo
Stanley ·
Awesome work and pics....love pics of fabrication work.
When you see the work and attention to detail that goes into a build like this it wouldn't take long to empty ones pockets.
Stanley wrote:Awesome work and pics....love pics of fabrication work.
Here here..................awesome work
Looks like the vw drag scene is gunna go off!!!!!!!!!!👍
London Bugger ·
wow awesome work, looks like Oz is getting some serious race cars out, what with the new CBB car, I have to get overthere to see a race one day!
Rob.
Dasdubber ·
Fantastic stuff - certainly can appreciate the amount of time not only to do the fabrication, but for all the headscratching and planning that goes into something so complex. Well done thus far!
Al
Can relate to the head scratching and planning in trying to make stuff fit into that space you have. Troy and I have stood at the back of his car in the building stages and just stared thinking for quite a while before one of us comes up with an option. then usually the argument on whether or not it will work begins LOL
10x10x ·
Trent has been away visiiting Ron Lummus so not much work done,
a few photos of new inlet manifols finished and the intake and throttle body
10x10x ·
mounting steering rack.
Stanley ·
fantastic stuff. Please keep them coming.
Are all front repairs as a result of the crash or are there upgrades aswell?
10x10x ·
no upgrades Stanley,
Suspension geometry, rack location and strut location have all been changed .
JVLRacing ·
mmmm$$$$ nice to see😎
10x10x ·
trent and ron
STOCK ·
LOOKS AWSOME GUYS
(CAR IN BACKGROUND ????)
10x10x ·
A few progress shots.
10x10x ·
some more
10x10x ·
seat mount, all new tin being made. Motor having final rebuild.
10x10x ·
trents car getting ready, very very rough paint job to make car one colour, then strip car if all goes well. want to run the car before finishing details. Engine ready to go back in , tune.
hellbugged ·
whaaa so nice 🥷 .....thanx for sharing!
JVLRacing ·
Eating *popcorn*😎
Stanley ·
very cool....and I like the paint 👍
Got a thing for satin black don't you Stanley 😁
dangerous ·
Thanks for sharing the updates.
What tyre size were you able to squeeze under there?
Looks great with the stock trim strips.
Love the black and og trim AND badge.
Dasdubber ·
Thanks for the update, I can't wait to hear some details of the shake down passes whenever they occur....we (well me in particular) always love more pics if you get the chance 🙂
Al
westi ·
at this rate i am going to have to change the colour of my shitter,everyone's gone black,you know what they say about black.
once youv'e had it you can't turn back,lol.
nah seriously,car looks hot.can't wiat to see it turning some tyres,how long before the day arrives.
10x10x ·
thanks for the comments, but dont get to excited about the paint, was done with a spray can , so the car can get out on the track soon. Trent hopes to have it ready in the next 2 weeks, although a few parts from the states have not arrived and will added later. Chasis, body and aluminium will be re done later so the car will be like new as it was before the roll over.
Dave the tires are 10.5 by 28.
Final fit of engine was done wed, waste gate pipe added and blow off. today start making new tin, then a couple of days to tune on dyno.
10x10x ·
more
STOCK ·
SHIT HOT TRENT
CANT WAIT TO SEE THIS THING GO
Stanley ·
mmm...nice view through the back window.
Can't wait to see some pics of it all buttoned up.
Top work guys.
and westi...black is the new pink
10x10x ·
progress on tin. Front will be finished today, start the rear. Very slow and time taking. Engine ready but still waiting for clutch from states to use on dyno. It should not be long before this stage is finished.
Mick058 ·
frig me that looks tops -where are you based?
Warwick will be huge this year.
vassy66T1 ·
Hot hot hot!!!
Everything is just supersized on that car 🙅
10x10x ·
front tin complete, started fuel cell
JVLRacing ·
This the best ive seen...the work m8😎 i luv tube chassis work m8 well done
10x10x ·
fuel cell nearly finished, rear fire wall 1/2 done but no clutch from the states. If the clutch arrives in the next week, trent may get a chance to run if not it will be another 7 weeks or so before trents car is finished as he will be away.
10x10x ·
engine ready to go
Dak-A-Tak ·
Love it Guys ! tin work takes so much thought and seeing pro's do it make me want to do my tin again in Dak-A-Tak bug .
What do you call that type of step (triangle design raised up) and what length can your machine reach in . Does it shrink much, over all size .
Great to see a shop that plays and builds all types of cars ( not just v8's ) Mast be some great jokes flying around the shop .😵💫
Play safe , Trent and c & v crew .
TRENT_DEMOS ·
Thanx jvl racing appreciate the comments....
Pete The triangle shapes are produced by a drop swage i will post some pics tomorrow of the process , as i will be working on the firewall.....tin is a slow process ...so far it has totalled 2 weeks work....and still going.
reub ·
This is a seriously nice car showing high quality craftsmanship.
Appreciate seeing the build progress...
TRENT_DEMOS ·
thanx.... glad you are enjoying the rebuild more to come
JVLRacing ·
Trent where is your work shop m8....😎
TRENT_DEMOS ·
jvl the car is being worked on by GD racecars and CV performance located in sydney .....look at www.cvperformance.com.au for details
TRENT_DEMOS ·
a few more shots...
JVLRacing ·
ok thankyou trent....keep the quality up looks the goods
10x10x ·
trents car is nearly finished, fire system , boost controller. finished fuel rails. Car is now 95% complete, some wiring to do, tune and he is ready to go.
10x10x ·
more
10x10x ·
more
reub ·
WOW
dangerous ·
Nice work guys,
you have been very busy.
I had forgotten how much work goes into these cars.
Should be a rocket.
You guys have been busy!! Top work!! Well done. Can't wait to see and hear this thing in action....
Boostn ·
Hot!
10x10x ·
the to do list gets shorter by the day, they all take time. New oil set up.
Boostn ·
I see Trent is on a tight budget, poor bastard.
A 1200 is slow ·
Nice!
I'm looking forward to seeing this car go!
Super1302 ·
great to see a lot more people here thinking out side of the square.
well done
Stanley ·
Drool.....all the other adjectives seem to be taken....👍
10x10x ·
todays actvities.
JVLRacing ·
deffently hard work......still a favourite of mine
dangerous ·
Good to see that it is now back to the tune-up stage.
Your tone indicates all went well.
Do you guys plan to run at Warwick if testing at WSID goes to plan?
063bug ·
10x10x wrote:todays actvities.
...nice to see someone dancing for joy..... 😂
10x10x ·
trent got back to dyno today. We had to order some tyres as the car was very hard to dyno on slicks. Preliminary tuning has been ok, still a long way to go.
trickysimon ·
dangerous ·
...and it isn't even looking like nosing over...
vassy66T1 ·
😵💫 WOW!!!!!!!
Even my 12 year old son is impressed by that👍
pete wood ·
that is awesome. how did you keep it on the dyno!?!
grogy ·
wow.... hope the seat bolted in tight
10x10x ·
Thankyou for the comments, trent will be doing more dyno work tom. just a little at a time. Dave that run is about 6000 rpm. We hope to run at least 9000. Boost is still low around 26 psi, we need to see around 36 psi.
The new tyres have made the car very easy to dyno, a frew straps and it has been ok.
Does anyone know when it will be hitting the track? Will he will be going to warwick?
Dasdubber ·
Fantastic stuff. I'm sure a lot of people will be eagerly waiting to see it make some shake down passes....myself included!
Al
vassy66T1 ·
Holy crap batman!!! Get it going straight and there will be some amazing numbers 👍
10x10x ·
sorry for the delay in report.
We have encounterd a few issues with the fuel system. The electronic fuel pump could not supply enough methanol once we started to increase boost. After much thought it was decided not to run the car with the current set up therefore trent has decided to switch to a mechanical fuel pump incorporating dry sump pump to carry out dry sump conversion with tank heater and pump to be supplied by pauter and ron lummus. these items should be leaving the US next week. After a little fabrication to install tank and heater etc, Trent will keep everyone up to date with tuning process.
polak ·
that is frikken mental🤪 do you get any traction on those rear tires on the track? or are they just for the dyno runs? great work, hope to see it at warwick!
10x10x ·
tires are just for dyno. Destroyed one set of slicks in 2 runs. So far these have done 6 runs and are still perfect. They actually give you a lot more grip than the drag slick.
10x10x ·
trent has been busy building a street car, but is now back onto the race car. just a few shots of new set up with mechanical pump, new hard fuel lines , oil tank/ heater. etc etc.
10x10x ·
more
10x10x ·
the car needs a lot of re-wiring now, motec guy will start this in 2 weeks.
reub ·
...street car? Beetle?
10x10x ·
beetle street/drag car, 51 ida and lots of nitrous, dave is currently re-building the box from trents first drag car.
JVLRacing ·
ONE WORD= CRAFT
BigWigRaceCars ·
Nice work! That car is looking good.
so will we see the car in Portland ???
10x10x ·
welcome along Big Wig, some of your parts being put to good use, thankyou.
Trying to get to portland , just need to wire the car , easier said than done. Trent has also purchased larger pauter heads, pistons etc which could delay things. This would mean re-making exhaust, inlet pipe work etc etc
Ron lummus will be comming out from the states to test a new clutch set up he has developed in trents car, it would be good to try and make this around portland, but trent keeps changing things.
Trent has also been working on his other German car
News on the street car. Dave B has finished the gear box, waiting for ron l to send some more parts and it to may be ready for portland
I have a few C63 and a CLK black come into work all the time. One of the young guys witha C63 has done some work to his car and recently(about a month ago) ran 11.37@121 at a test and tune at willowbank.
would be good to see if you could get RL out about the same time as Portland though👍
JVLRacing ·
Really like to hear this bloke make it to the track!...
reub ·
Or even what the final dyno results were...👍
JVLRacing ·
Iam bumpin this to the top....i like this!!!!!😎
10x10x ·
Trent has been busy since Christmas. Have been waiting for the motec installer to finish, he works one day in every three weeks on the car. It should be finished in the next month. Trent got sick of waiting so is now half way through building his second drag car. Another pauter has been ordered running large carbies. The gearbox has been re built by Dave b. And gd racecars has again built a half chasis car. The car has a custom front beam, 4 wheel disc etc etcThe piston, barrels and heads will come off the turbo motor and a new more serious set up on the turbo motor to run high psi has already arrived . More in 4 weeks as Trent is away watching the Brazilian beetles run
Stanley ·
pics pics pics.......please
2 cars......🙂
TRENT_DEMOS ·
Hey 10x10x have you got any pics?Please?
TRENT_DEMOS ·
Hey Matt 2 cars ... lets go racing !!!!!!
You only need two !
TRENT_DEMOS ·
Our new company car .....churrasco.com.au
dangerous ·
TRENT_DEMOS wrote:Our new company car .....churrasco.com.au
Mmmmmmmmmmmm!
dangerous ·
westi ·
nice work as per usuall,it's good to see.nice car's being built,i love it .
i can't wait to get some more pic's of this one.
please don't take offense ,because everyone else thinks the same,but they won't ask.which olympic's will be on, summer or winter and when we expect to see either of these cars make some passes,i can't wait anymore😂,
everytime i go to a vw event i think is he or isn't he going to turn up.🤪
no pressure to perform we just want to see more cool car's getting out there.😉
realy wish to see one of the car's hit the track soon.
Stanley ·
wow...that's a nice tranny
SuperOwen ·
I'm more interested in the BBQ! I might have to help fund the build soon....😀
Agreed its nice to see builds done by professionals. Inspiring stuff.
SuperOwen ·
Stanley wrote:wow...that's a nice tranny
You need a holiday in Thailand!
TRENT_DEMOS ·
Hey Westi...thanx for the positive feedback, not sure what olympics , but just going flat stick... i will try to pressure 10x10x for some more pics...
Dave thanx for the pic if you do not mind i wil email a couple more for you to post as i am hopeless with technology.
dangerous ·
TRENT_DEMOS ·
Hi All over the weekend it was a weekend of racing here in curitiba Brasil....here are some pics...
JVLRacing ·
keep it goin trent,😎
TRENT_DEMOS ·
Thanx Bud ... talking to Glen the fabricator as we speak....
JVLRacing ·
TRENT_DEMOS ·
Is Anyone interested in some photos and updates from the VW WINTER OLYMPICS?
JVLRacing ·
ok....bring them on...😎
reub ·
10x10x ·
trents second car update
to avoid technical advice rear disc is for dummy assembly ie not correct side
10x10x ·
more
10x10x ·
rear
10x10x ·
rear
TRENT_DEMOS ·
Hi All Custom Front Beam is made totally from chromolly .....it is narrowed 6 inches...
TRENT_DEMOS ·
Rear suspension has been narrowed also 6 inches and raised a total of 4 inches ....
TRENT_DEMOS ·
Rear guards have been zeused on to create more clearance to the wheel .....
Shifter mount to suit mse vertigate shifter
Mount for staging brake.....
TRENT_DEMOS ·
Rear brakes supplied by RLR, to suite wide 5 and utilises wilwood calipers...
reub ·
Nice work mate. So this car is strictly for the strip?? Looks the goods so far....
TRENT_DEMOS ·
Thanx Guys .. this car will be used predominantly for drag use and limited street, but will be driven to and from the track...
It will be running a 78mmx108mm pauter engine with 52mm carbies and a nitrous set-up with full custom cooling and alternator as well as full exhaust system using collector pipe and mufflers from burns stainless....
JVLRacing ·
Boys...wats goin on with other car?
TRENT_DEMOS ·
Hey JVL other car is at final stages of motec install ....an exremely large install ....please let me know if you would like to see photos and i will try to get 10x10x to make a visit and take some updated photos?
Mick058 ·
PHOTOS!!! YES
JVLRacing ·
TRENT_DEMOS wrote:Hey JVL other car is at final stages of motec install ....an exremely large install ....please let me know if you would like to see photos and i will try to get 10x10x to make a visit and take some updated photos?
Mate real interested...pretty impressed that u havnt given up on ur build mate...keep it goin😎
Stanley ·
nice welds....👍
When I saw the speedo I thought street and then thought naaah...surely not. Yet it is..👍 again
Turbo54 ·
cool builds, whats the car next to it, centura or cortina?
fast68 ·
Hi guys has this car run yet? fantastic peice of work.
TRENT_DEMOS ·
Not yet ...But the wait is over.
WE ARE READY......ANDRA Tech inspection this week .........
reub ·
More pics?
TRENT_DEMOS ·
Sure.. I will take some pics and post them tomorrow...
reub ·
Sweet dude👍
Boostn ·
Sexy car Trent.
Good luck with it all !!!
TRENT_DEMOS ·
Thanx mate.....
I am having trouble posting pics... If anyone would like to kindly volunteer their services, i will email the photos to them so they can post them for me...
Thanks in advance... Trent.
dangerous ·
send them to me dude.
You still have my email?
DB>
TRENT_DEMOS ·
Thanx bud .... Can i mms you?
dangerous ·
here you go
dangerous ·
more
dangerous ·
last ones
got a vid too but it is in quick time.
Can i load that up on you tube?
How the hell is that ever going to hookup dude?!!
awesome power!
Thanx DB ... Not sure how it will hook up either... I am open to suggestions.
Boost control is working well.That run is 23-24psi and holding with no nitrous.
Hopefully it is soft enough to start with.
Absolutely top build.
Thanks for sharing.
So how long till the big day to hit the track or are you holding back?
TRENT_DEMOS ·
Thanx Matt
Andra tech inspection tomorrow at midday.
I am aiming for Full throttle Fri on Dec3......
Cool, good luck with the tech, not that you need it, I'm sure it'll go through smoothly.
How about the streeter, is that nearing completion?
TRENT_DEMOS ·
Thanx....
I will send DB some pics of streeter tomorrow...and maybe some more video!!!!
TRENT_DEMOS ·
Ok , so car is passed and forms have been filled in for log book and ANDRA license.
Motec setup is complete and i will send a video to DB of car on 2-step at 6000rpm and 20psi of boost ....along with some photos of the streeter.
Thanx
dangerous ·
Look forward to seeing them dude.
dangerous ·
dangerous ·
Trent's streeter
dangerous ·
more...
dangerous ·
Looks like this streeter is getting Pauter heads.
TRENT_DEMOS ·
Thanx very much DB, i appreciate your help and enthusiam...
reub ·
How are you going with engineering of the street car for rego?
Looks sweet as👍
fast68 ·
very cool😎
TRENT_DEMOS ·
Hey Reub, have not even gone there yet.. Trying to get race car sorted first.
Do you have any suggestions?
Bead rolling on the tinware behind the front seats is awesome mate!! Top Work!!
TRENT_DEMOS ·
Thanx bud ...
Will have some more tuning vids tomorrow ... The dyno has had a problem with the mother board and been out of action...
I changed the oil today, all was good ....adjusted rockers and ready do a two step and a nitrous tune...
Thanx
Trent
SuperOwen ·
Just some pics of the car from 4th of march, any news?
hmmmmmmm.....never a good sign when people pushing the car back
hope all is good tho.
bump
JVLRacing ·
well done trent😎
Dak-A-Tak ·
Long time coming , I'm glad the time has come !! Great video guys . Tell more please ?
No times , just out testing , Vic doing the driving .
dangerous ·
ian.mezz ·
dangerous wrote:
nice burnout , what times did it run ???????😊
HotRodMatt ·
Solid burnout! Can't wait to see a full power pass.
westi ·
engine
Stanley ·
Awesome car guys love it.....especially the colour
essex ·
Loved the videos!
TRENT_DEMOS ·
Hi all...
Thankyou for all your support and encouraging comments.
Firstly i am wrapped that the car is now on the track ... Even if it was for only a burnout.
We attended a friday night meet at sydney dragway at short notice as we are still in the final stages of tuning.
The car is being driven by Vick Elfes, the V of cv performance...
Vic drove the car into the burnout area and went through procedures and the car bogged down. We suddenly realised that the burnout limiter was set too low .
He then switched to race mode and then produced a very strong burnout with the engine sounding strong.from the outside we were happy , but vic had another story with a warning light of low oil pressure.
A decision was made to take the car back to the pits ...
First thing monday morning i pulled the engine out and then stripped it to reveal signs of poor oiling on number 1 and 3 big ends..
We are currently rectifying this problem as we now run a dry sump and at this stage we have put the problem down to a simple case of setup due to cavitation.
I have put aside next week to have the car sorted and plan get the car ready for friday before jamboree...
Thanx
Trent.
fast68 ·
Any updates?
TRENT_DEMOS ·
Hi All
I have been busy getting the street car ready for the vw nationals over the weekend.
It was a great day and i enjoyed showing the car.
If any forum members have any photos of my car from the weekend please feel free to post them in this thread .
The race cars new engine has been dummied up for fittment of headers and intake and fortunately it all fits.
I have completed plumbing and today i removed the engine for final stages of build. Tomorrow i will be measuring pushrod length and sending the pushrods to GD to cut.
dangerous ·
Stanley ·
That is fantastically nuts.....👍
whathaveidone ·
are you gunna bring one or both to warwick??????
TRENT_DEMOS ·
Looking like both at the moment...
whathaveidone ·
Awesome, cant wait to see them in action!!!!!!!
TRENT_DEMOS ·
Thanx ... The feelings mutual!!!!
whathaveidone ·
LOL.... ill give you a run in the street car but ill leave the race car to the big boys!!!!!
Geez you'll be a busy boy mate driving both cars LOL. Better hit the gym for a lot of running LOL
Fantastic that you will bring both cars up to Warwick!! Hard enough to bring one net alone 2!!
TRENT_DEMOS ·
I better bring some spare nos jets.lol
whathaveidone ·
TRENT_DEMOS wrote:I better bring some spare nos jets.lol
TRENT_DEMOS ·
Hey Brendan .. I better sign up before i think about all that training and change my mind.
SuperOwen ·
Nice grocery getter!
TRENT_DEMOS ·
Ron Lummus Racing .... Parts Available in OZ soon
TRENT_DEMOS ·
It's finally here ... Rlr Australia..
I am proud to announce that Ron Lummus And I have formed Rlr Australia.
Check out Rlr Australia on Facebook and LIKE us to view info and new products that will be available In Australia.Or send any inquiries to rlraustralia@yahoo.com.au
There is plenty of new products coming out soon and in particular one that will interest all us drag racers ... It's called rev6olution.... Keep an eye out for it as I can assure all of you that it will impress..
Check it out in the news section.. Updates today..
JVLRacing ·
only thing i can say ...pick up ur spanners after usin them🤪😎
TRENT_DEMOS ·
Update ... Work will begin again today on the street car, just a little time off after the big push to get the car to the vw nationals.
The race car is coming along nicely too with the pushrods now been cut to length and the piston to valve checked yesterday. The pistons are now at the machinist and then i will have a final dummy assembly.
Dak-A-Tak ·
Good to here , what happen to race car engine after the burnout ? Sounds like major rebuild there .
Will you be posting lummus forsale parts up on website , so we can see them ? Be good to see them instead
of phoning up .
TRENT_DEMOS ·
Hey Peter
Race car engine lost oil pressure ... We were running a new dry sump set up, that enging has been rebuilt and is now in the street dub...
I am building another pauter engine of the same capacity but using later design cylinders and heads... This combo is the new race engine... The idea being all race program parts will become spares and work in both set ups.
TRENT_DEMOS ·
RLR ... Photos and pricing will be on the rlr australia facebook and on the cvperformance website very soon ..
apmitchell74 ·
That street Beetle looks insane! That's going to be the fastest street registed Beetle around! Nice job...
Nice job Trent and smart thinking on the interchanging of parts from race car to the street car!!
LOWBUG ·
Wow, saw the "street car" at the nats, thats a great bit of kit, are you really going to register that and drive it on the street?
TRENT_DEMOS ·
Thanx lowbug .. Yes it will be a driven streeter.. I can not wait .. Perhaps it will see a cam change .. But this will be done after warrick..
TRENT_DEMOS ·
Hi all please check out some photos of products that are available from Rlr Australia on Facebook...
Updates with many pics of products....enjoy
LOWBUG ·
Trent, how are you going to achieve registration?
TRENT_DEMOS ·
Hey lowbug ... The car has rego already. There will be a few obstacles getting an. Engineers cert , but i will take it step by step.
LOWBUG ·
Really keen to see how you get on with eng cert,(might have to go see your guy for some mods I want to do) it would be good to see some appreciation for all the the work you've done by getting the cirtification. How do you think you'll find using the vertical gate shifting on the the street?
TRENT_DEMOS ·
Sounds good ... Vertigate shifter will be a chore... On the street anyway .. This car will not be a daily .. But something special that will enjoyed for what it is..
LOWBUG ·
Trent what sort of clutch set up are you running in it, something easy for the street or strictly race set up, whats the expected power output?
TRENT_DEMOS ·
I am using a Rlr black magic disc and 1700lb pressure plate ... I will tune the engine and nitrous to 350hp at the wheels .. This clutch setup is available at Rlr Australia. Check out image on Rlr Facebook page.
LOWBUG ·
I've heard that the black magic clutch is very good, good to know this stuff is available here in aus, are you looking after distribution of RLR gear here? Sorry I don't do face book. Is the car going to be full weight or stripped out to keep it light, whats the end plan, paint job maybe? This is exactly what I want to do, maybe not such as big a engine or No2, Im just concerened about the fine line of drivability and keeping it registered, it also will be my weekend toy and not driven much. What do you reckon?
TRENT_DEMOS ·
It's launched !!! The new Revolution 6 clutch pack ... Images on the Rlr Australia face book ... Check it out!!!
dangerous ·
Awesome, when can I have mine?
TRENT_DEMOS ·
Thanx mate ..just let me know....
Just what I've been looking for...
What sizes, spec and how much $$$
TRENT_DEMOS ·
Matt
6 inch disc.. Single for naturally aspirated and a dual disc for turbo engines..
Dual disc fits inside std bell housing ... Pricing details will be released this week ..my setup was used for photo shoot for us mags and is on its way as we speak.. If you would like to come and check it out please let me know...
TRENT_DEMOS ·
Sorry lowbug a bit side tracked ... Yes i am the importer for rlr products in australia ..
The streeter has been on a fairly serious diet and its colour will be white .. Hopefully it will be painted before warrick .. If not it will run in primer..
TRENT_DEMOS ·
Introductory special .. Price release .. Revolution 6 .. Limited numbers at this price ...
Check out Rlr Australia on Facebook for details
Trent, I don't do Facebook, please PM me email contact for spec and pricing.
Setup will be for high hp N/A road racing application
some of the attached comments have Ron Lummus packing his helmet and race suit????
nice stuff.......more on silly ole facebook (no log in required);. Looks like the drag car (because this white one is THE streetcar 🤪).....is close again too
Gold. Love the std steering wheel amongst other things
Flintstones ·
Niiiiice👍
D
Trent
Are you going to have one of the 3 cars running at the VW Drags in Feb 25th
JVLRacing ·
I will say this outside the square.... the work on hes cars r the best ive seen on here by farr, quality and presentation!!!...results will follow
Well done😎
vassy66T1 ·
Cool as 👍
Dasdubber ·
Very nice mate - looks like fun trying to get it onto the tilt tray without scraping the nose!!
Can't wait to see it all finished.
Al
cnfabo ·
top work does not justify....so all im going to say is HOLY $H1T.......🤪🤪🤪
amazing work....
Looking good Trent!! Bet your keen as to get behind the wheel!!
TRENT_DEMOS ·
A big Thanx to all got your encouraging and kind words...
We made it to Wsid last night.
First the good news Is that we have finally solved the oiling problem that we discovered after the burnout of last outing.
The bad news is that we found the next weakest link...
After the burnout all Was looking engine wise so Vick staged and launched with a soft tune at 6300rpm and then lost all drive.
I took it back to CV this morning to discover two broken axles..
Box will be out Monday morning and off to DB for some sorting.
Thanx
Trent
TRENT_DEMOS ·
Sure .. Race car will be going unless something unforeseen happens ...
hellbugged ·
How about February 2013 Trent???
Yes didnt C U there last Feb
how about this feb 23rd coming
Dak-A-Tak ·
Trent , any vw news , mate ! What happening with your car , or racing plans .
Know you don't do things by halves , hope that crazy crazy ride will be on track soon .👍
Busy cooking up a storm at the restaurant!!
hypo-vw ·
LIFE IN THE LOW LANE wrote:Busy cooking up a storm at the restaurant!!
thats for sure !!
I went to Coogee to see Trent some weeks ago and couldn't believe just how much he had on his plate with not only his 4 established resturants , but he had just opened another across the road and his wife had just had a baby .
Trent was kind enough to take Louise and me for a tour downstairs through the kitchen of his newest resturant , and I must say it looks really well set up and extremely professional .
I'm sure when he gets the first opportunity he will be playing with his toys ...... well done Trent !!
