Is it only the kombi/caravelle bellhousings that are removable? if so, is the bolt pattern where it bolts to the box the same for all models?
Old Dubber ·
It's the same bolt pattern for the Kombi 1600,1700, 1800 and 2ltr, don't know about the Caravelle
Secoh ·
So can I bolt a type 1 motor to a kombi box ok?
the beetle box never had a removable bell housing?
Baja Wes ·
the beetle never had a removable bellhousing.
To bolt a type 1 into a type 2 trans, you will need to put a type 1 input shaft in it (or cut a little off the type 2 one). This applies to gearboxes made for the type 4 engine.
Secoh ·
Thanks Wes....the reason for the questions, is I have a renault 5sp box now, and found someone that makes adaptor plates to fit a vw bellhousing to the renault box.
however he didnt say what type of vw bellhousing. I'm hoping to use a caravelle one so I can use a hydraulic clutch.
